Ryzen 8000 does not support pcie 5, that's why it's listed separately to Ryzen 7000/9000 chipsyer, fair enough
I dont know the 8000 series. just the 7000 and 9000.Ryzen 8000 does not support pcie 5, that's why it's listed separately to Ryzen 7000/9000 chips
he's unlikely to need that muchVram though! and it's a long wait for somthing that is going to cost loadsrefresh models which should come with more vram
Again appreciate the advice albeit find myself a bit lost with some of your high level chat
This a good combo to start me off?
Seems to be great price for all things im after ?
Seperatley the parts can be had for the same money but as a bundle then I would check warranty period, if it's 3 years from Overclockers then it's a no brainer.Again appreciate the advice albeit find myself a bit lost with some of your high level chat
T500 is a high-end drive with TLC nand and DRAM (rated endurance: 1200 TB written), the P310 is a dramless QLC drive (rated endurance: 440 TB written).Is the one you have suggested better than the 2tb one I specced?
I agree and remember when i specced it for last build it was a good choice. ,however Im looking to transfer as it sits. Looking at cooling for the 9800x3d doesnt seem to much of a problem with either choices above.Do you still have the Noctua D15? If so just get a AM5 bracket for it, no need for a new cooler. Silly to have such a expensive cooler and not use it.
Keep in mind that the board only has 3x M.2 slots and that smaller drives have lower endurance because there's less flash to distribute the writes to.Knocked the SSD down to a 1TB also to shave some money off as It will only really be used for the OS
Tbf ive been running half the storage ive specced for the duration of this PC and never really had a problem running out of space. May add another later down the line and move the OS onto a faster Gen 5 or maybe 6 use the 1TB as storage .Keep in mind that the board only has 3x M.2 slots and that smaller drives have lower endurance because there's less flash to distribute the writes to.
Case Looks fine but just check top clearance as the arctic aio needs 63mm .Final request this look ok to transfer old set up into?
https://www.overclockers.co.uk/kolink-unity-lateral-performance-midi-tower-case-black-ca-07n-kk.html
