New DAC to play with - Chord Mojo2
Man of Honour
Man of Honour
23 Dec 2002
London
Curiosity finally got the better of me recently and I grabbed a s/h Chord Mojo2 to see what all the hype was about.
Every so often I like to see whether some of the new technology really has made older kit defunct. So far, not really. In the last year I tried an Arcam ST60 (uses an ESS9038 IIRC) and a Gustard A18 (uses an AK4497 IIRC). Neither were that special.
This time round, I thought I'd have a play with a headphone focused DAC, i.e. a Mojo2. For those unaware, Chord have for over a decade now being selling DACs that don't have the usual run of the mill ESS, AKM, AD or similar off the shelf DAC chips. Instead, they use high speed processing chips running custom code to do the conversion. I believe that the term currently used is R2R.
The Mojo2 incorporates this Chord tech into a miniature DAC that is around the size of a pack of 20 cigs.
It's a bit weird looking, but very well built. Inputs/outputs are also a bit odd, though I understand why given the space available.
Inputs are USB-C, USB-Micro, Optical and mini-jack coax. Output is two headphone 3.5mm ports. No RCA, no balanced.
From doing some reading, using the optical seems recommended, at least by one chap who I know and genuinely knows his stuff. With it's size, and the fact that is has a battery, it can also be used with a phone. I'll try that out when my new phone arrives later this month.
Initial listening, very impressed. Presents a lovely image with a paid of HD25s.
I wanted to get used to it's presentation style before conducting any genuine side by side comparisons. When I do I'll be comparing it as a headphone DAC with a Meridian Explorer 2, a Director and an MS200, then as an amp against a Head Canamp and a Little Dot3. For headphones, I'll be using the HD25s, HD600s, HD450s and Beyer 990s.
At some point when I'm feeling flush and there's a good used example around I keep meaning to get a Chord Qutest to connect to my Wiim as a kinda end-game solution for digital playback in my living room....although I do mostly listen to CDs and vinyl still so it's hard to justify it though! Be interested to hear how the Mojo fares...
Yup there was a time when I know all this about the mojo, it’s got 6 output devices to reduce the ouput impedance which means plenty of current on tap.
R2R is also known as a ladder dac, the high end ones use differential signals to minimise the error from the dac resistors. The maximum you’ll get out of a dac is about 27bits before the components themselves become a noise problem.
Each resistor corresponds to a different voltage level. The FPGA switches which is used rapidly to created the output sound.
The FPGA in the mojo runs their own proprietary transformation between the digital signals (of varying sample rate and bit depth). There’s even open source and people have created their own FPGA and other mechanisms todo the same. Just another way to cut the carrots.
The mojo has a large power reserve compared to others. Other than that it’s quite basic (not much has changed in designs for years).
No, haven’t tried those. I kind of assumed that the Gustard and ST60 would be vaguely representative.
Interesting. Owned a few dacs over the years and could never really tell a difference between them.
I wouldn't mind listening to an r2r dac to see though.
What if it's sourced from overseas?
Sorry, only kidding and this is NOT the right forum to discuss it in.
If you're in Surrey and fancy a listen, happy to oblige.
