Drove around the block to fill it up, and, my gawd did it need a clean. Do a quick bucket wash and rinse once over. The soapsuds came off it black. I can now see out of the windows.
Also the trusty old Michelin 15-20 year old 12V tyre pump died.. the plastic. around the screws failed so .. new tyre pump time. Looked at a number but in the end bit the bullet and paid for another Michelin pump - this time the larger capacity '4x4' pump with pressure set stop, deflation valve and a screw on rather than the horrid push fit connectors.
Works a treat after being a little concerned it can pull 180W (15A) through the 12V socket. Much faster and I think it pumps quite a bit more volume than the old pump. I have a pump and charger in my wheel well all the time as they've saved me a few times.
