- 17 Mar 2025
- dorsetshire
Hello again
so going to be adding the second gpu in soon as planned, was going to just bung it in the empty x4 slot that is off the chipset....
thats my back up plan in case this idea isnt going to work [and i have a feeling it wont work so its probably the plan a with this idea being plan b in case i can do it]
can I with this motherboard bifurcate the primary x16 slot [which currently hosts my gpu] into 8x8 so i can then run both gpus in that slot.... thus relieving any
possible bottle neck with the other slot being on the chipset and also just as importantly it would leave that other x4 slot empty which i can then bung another nvme
drive in [which ive actually just got another nvme on its way from ocuk lol]
even better if it can do 8x4x4 as the second gpu only has 4 lanes anyway [6500xt] then i could in fact bung the 9070xt in the first 8 lanes then the 6500xt and a further nvme could use the other 4 and 4
im guessing that last idea is probably very much not possible
BUT if i can at least get both gpus onto that slot and use the x4 on the chipset to bung this 990 pro ive got on its way that would be a massive massive bonus.
Also other than having to set up bifurcation in the bios im assuming i need to buy some adaptors/some other hardware to actually physically facilitate this......
google isnt really helping me much here i can only find people trying to add 4 m.2s using the asus hyper cards and im guessing they are putting hte gpu somewhere else or using onboard igpu or something
its not giving me a clear yes you can or no you cant kinda answer.
is this doable?
i should probably stop messing about and upgrading stuff but theres just too many obvious improvements i can do so im trying lol
Any info gratefully recieved
is this doable?
