The Radeon RX9070XT / RX9070 Owners Thread
im fairly sure the 6xxx series and 9xxx series both use the same drivers
only looked into this the last few days as im about to add a 6500xt to a system that has a 9070xt in as well and happily noticed they would be on the same drivers
doesnt mean il be able to bung the 6500xt in and it will just work alongside the 9070xt without issues but it does make me more confident it shouldnt be too much hassle it running both side by side at least
I noticed some odd behaviour with LACT. I found that if I didn't hit "reset" before making changes they didn't seem to be applied. There have been a few patches to it on Cachy but I haven't had chance to retest. Not sure if it is a bug or a feature ;)
LACT seems to be editing the file correctly (power1_cap), but the card still seems to throttle ~340W.
That’s very impressive.
Absolute worst I've seen it is a bit above 3GHz, and that's with everything in effect under the sun including full RT, which I guess probably adds wider load to the GPU, draws more power, and means it has to clock down a bit compared to a less all out workload.
Happy with that though!
