- 26 May 2008
Curious as to what are deemed as the quietest PSU brands these days.
Considering a cable kit and swapping PSU's around in my systems, but none are ATX 3.1, and a full cable kit to cover all eventualities can cost quite a bit when you want a black/silver cable theme, and only see the 24pin and 8 pin CPU cables.
In the past I used to go with Seasonic. I have a TX Prime 850w in another PC not 3.0 though, but the case fans drown it out, and it would need a cable kit for that if I decide to move it to my latest PC, but that old PC is still in use, the other is a Seasonic SnowSilent 650w and not enough wattage for the newer build. I may well just get a cable kit and transfer the PSU, but I could end up back where I started, the cable kit I like are Cablemod Pro Modflex, which also would be getting an additional 8 pin PCIe, 8 pin CPU, and 12v Nvidia cable as the kits are rather basic, full kit with extra cable costs are around £165. Classic is an option too, it's just that they don't seem to list seperate 8 pin PCIe or CPU cables.
Current PSU is a CoolerMaster V1000 1000w gold fully modular, with a CableMod Classic Modflex cable kit, it's a great piece of kit, based on one of the older Seasonic platforms. This has seen little use in it's life.
The problem is although the fan was rated as reasonably quiet in it's day, it's pulling through the dust filter of a thin steel NZXT H500 case, and the gentle whir of that fan seems to be amplified with the location and case.
It doesn't help that my PC sits on the top shelf of an audio rack, and that hard top shelf is pretty much ear height and the room is pretty dead sounding, making that PSU fan the 1st thing my right ear picks up. Obviously the rest of the fans are gently whirring away, but with no load or load the sound is not changing much and gets louder as my ear approaches the PSU area, it is simply that PSU fan signature I am noticing due to it being at ear height about 1.5m away.
