I think a the board I have supports pci 5.0 I am running a 5090There's two main feature advantages of X870 over B650: PCI-E 5.0 graphics and USB4.
Depending on your graphics card, the difference between PCI-E 5.0 and 4.0 may be nothing, a few percent (e.g. 1-3%), or a lot.
USB4 offers no obvious benefit for gaming.
The Strix B650-A has a PCI-E 5.0 M.2 slot, but it does not have PCI-E 5.0 graphics.the board I have supports pci 5.0
A 5090 loses around 1% with PCI-E 4.0 graphics.
NVIDIA GeForce RTX 5090 PCI-Express Scaling
The new NVIDIA GeForce RTX 5090 is the first high-end graphics card that makes use of a PCI-Express 5.0 bus interface. Are you in trouble when trying to run it on PCIe 4.0? What about x8, like when an SSD is using up some bandwidth? We've also tested various PCI-Express 3.0, 2.0 and 1.1 configs...www.techpowerup.com
That said, if you can afford a 5090, then I'd just return it and get the X870 board, unless you already installed it.
In that case, yep, you have PCI-E 5.0 graphics.Sorry the board i have is a
Asus ROG Strix B650E-E Gaming WIFI (Socket AM5) DDR5 ATX Motherboard
I also going to be running 2 2tb name drives ?In that case, yep, you have PCI-E 5.0 graphics.
Unless you're desperate for USB4, I'd keep it.
Though, note that there is a small chance you may need to update the BIOS with a 9000 series CPU.
I believe it is best to use slot 1, 2 and 4 with that board.I also going to be running 2 2tb name drives ?
