Curved or Flat screen ? Recommend me a monitor around 32 inch.
12 Jul 2012
I still can't decide which monitor to get, would you go curved or flat screen if your main uses are using the monitor as a bedroom type tv screen as well as it being my main PC screen. The main uses are normal computing, some photoshop editing occasionally, video editing as i have a drone and i'll be getting into that soon, plus i watch a lot of flims and youtube etc whilst chilling out in my bedroom, i'm open to suggestions, i don't game so ideally the best option for the things i mentioned, thanks.
I switched from 32” curved to flat and definitely prefer the latter. I’ve also had 34” ultrawide curved and flat, and it was only at that width that I found curved to be an improvement.
Also, if you’re using it as a TV type screen in your bedroom your viewing distance is presumably going to be quite high, further negating any benefit of curved.
AAAND for any kind of content editing you’re going to want a flat screen for the best representation of what the viewer will see.
That makes a lot of sense, thanks
It really isn't - on my 5700x3d/6800xt machine I run games at 1440p on my 42" LG OLED as a 2nd monitor to allow higer graphics settings, pixel density is something to be aware of, but I find it fine.
Each to their own I guess. I had a 1080p 27" for about a week and the pixel density made me twitch.
Viewing distance will also make a huge difference, as will the monitor's ability to scale the incoming resolution to the panel's resolution. I'm guessing your LG is 4K.
ummm your TV or GPU is scaling 1440p to 4k. Not the same thing at all having a native 1080p screen. I've got a 1080p 50" plasma and text is blurry.
There's probably a optimal PPI for monitor size/distance/eyesight/content/pixel structure.
Regarding the curve of a screen, is it the higher the number the lesser the curve, as in 1800R has less curve than 1500R?
Been using a Samsung Odyssey Neo g7 for a couple of years now it has a 1000r curve but tbh you get used to it really quick I barely even notice it anymore.
Yes that’s right. Some of the new lg monitors have a 800R curve which is horrible.
Great if you play like this
Your use case, I would get flat.
I think curved reallty comes into it's own on U/W, partiucalry in gaming for example a 1800R curve on 34" UW is really nice.
If I went back to 32", i'd be undecided whether to go flart or curved though.
