True 2 slot card options?
10 Oct 2008
Are true 2 slot gaming cards still a thing? It can be relatively long with a little over 38cm to play with, but has to be a true 2 slot card not 2.5 slot. Any recommendations? Thanks.
Thanks for the reply Tetras. It was a review of the RX 9060 XT that made me realise how dated my card was. So perhaps something around a RX 9060XT 16GB, RX 9070 or RTX 5070 would work well?
Zotac's twin edge are usually compact cards, e.g. the 5070 is listed as 40.6mm.
Powercolor's Reaper is one of the smallest 9060 XT cards, it has a listed height of 40mm.
You could also look at the blower workstation variants, but they're usually too expensive to justify their performance versus the regular cards.
The Zotac Twin Edge's I've used in various builds have all been spot on, I'm even using a 4070 version myself.
Lovely little compact card, quiet under general use with a fan curve, good temps.
