Where are these from!? I'd love to get one to transplant my work PC into.
Mine arrived aswell lol.
Nice. If you look at the pics, at the top corner of mine it was damaged. They’ve been really good though and have sent me a replacement one, I chose the Docker variant this time. Should arrive in a few days.
@DJ_Bucho I have. Very easy once you remove the panels. You just have to be a bit delicate because the screws go into the aluminium.
I put an AMD 9600X3D on an ASUS X870I gaming and a Noctua low profile cooler.
I had an old AMD 580 GPU I chucked in as I’m running proxmox on it so no need for high end GPU although my RTX 5080 SFF would have fit.
Thermals are ok, not good but not bad. Although you can fit a standard 120x25mm fan at the bottom I used a Noctua 120x15mm as the cables from the PSU would have interfered.
Thats incredible!
Wonderful build! Those hexagonal BP fittings aesthetics or something else?SSUPD Meshroom S - Workstation Build with RTX A2000 12GB
Intel 2655K
Asrock B860i Lightning WIFI Motherboard
Antec SF850X PSU
G.Skill CU-DIMM 8600mhz 64GB DDR5 Memory Kit
Kingston Fury Gen4 nvme Storage
Nvidia RTX A2000 12gb Graphics card
Custom 3D Printed Front Extension and Feet
Jake Custom Wood Paneling
Bitspower Watercooling Components
Bitspower REVO Tubeless Waterblock.
Bitspower HEX 14mm Hardline Fittings.
Aquacomputer D5 NEXT PUMP
MODDIY Custom Cabling.
New build this week, trimmed 3 years of stock market gains so a little treat for myself.
Sorry about reflections, ill try get a better one later.
Lovely budget system, hopefully the stock market will pick up and you can upgrade to a decent system
J/K, very lovely build!![]()
