The weapon unlocks do take quite a while. Currently using the SGX and with the 8” extended barrel it makes it a bit of an all rounder.
They'll be flogging unlocked weapons in the next few weeks almost certainly.
i would be surprised if they didnt lolThey'll be flogging unlocked weapons in the next few weeks almost certainly.
Just tried this, stock:
CPU fix (12700KF so 12, 12 then 20 for me):
So a 26% drop in CPU utilisation and with that a ~20W drop in CPU power draw. the 5fps gain could be run variance as on a different server the 2nd time round but still, seems decent given basically no change in performance but the CPU is running lighter and 5 degrees cooler.
I know the core numbers, just not how it should translate to that config file.Check your task manage CPU tab to be sure if you're not sure of your core numbers.
Wonder what/if any impact on 1% lows...
You could try it and see what you get I guess?I know the core numbers, just not how it should translate to that config file.
8 p cores no ht
12 e cores no ht
20 total cores
So 20 20 20 Which doesn't sound like anything the game wouldn't already know. Saw some guy saying 20 20 7 which looks weird but he seemed confident.
There doesn't seem to be a frontline on any of these maps - constantly attacked from all angles, so many ways to pass through the level.Yeah I'd seen those comments, I was just whinging. As others have said, maps are smaller and there seems to be more players crammed into them. Plus there's a lot happening on screen and I have difficulty sorting it all out so probably not reacting as quickly, even if I try and be a little stealthy some buggers usually camping or already spotted me and takes me out.
Intel users obsess over FPS tweaksStock:
12-10-2025, 21:52:40 bf6.exe benchmark completed, 28812 frames rendered in 227.172 s
Average framerate : 126.8 FPS
Minimum framerate : 104.4 FPS
Maximum framerate : 146.5 FPS
1% low framerate : 89.4 FPS
0.1% low framerate : 68.2 FPS
User CFG:
12-10-2025, 22:00:03 bf6.exe benchmark completed, 29972 frames rendered in 229.313 s
Average framerate : 130.7 FPS
Minimum framerate : 107.2 FPS
Maximum framerate : 146.9 FPS
1% low framerate : 89.9 FPS
0.1% low framerate : 72.7 FPS
That is Overkill 4K DLSS Perf with no frame gen.
I had the same issue in the beta and on my first few games today, a combination of disabling the below has definitely helped it feel a bit more snappy:
1. Frame gen (I know this adds some input lag).
2. Uniform soldier aiming - counterintuitive as have always used this in BF titles, but feels better 'off' in BF6 to me.
Also make sure you disable all the motion/ camera shake settings etc.
yup so many times ive started unloading half a clip on a assault rifle into some one and they seem to turn around and get me in a hit or 2......
any one got any idea what process is still running after the game crashes with no error messages? fed up rebooting to be able to launch the game again when it does crash. if i could just go task manager and kill the process win instead of rebooting.
