Morning all
I have the headphones below but they are starting to fall apart, only play fps so nothing too crazy, any recommendations in the £100-£150 ballpark? I have a Creative A-E5 pci card - thanks in advance
Philips Fidelio X2HR Over-Ear High Resolution Wired Headphones | Open-Back Design | Double-Layered Ear Shells | 50 mm Neodymium Drivers | Deluxe Memory Foam Earpads
I think part of the answer will depend on whether you liked the sound profile. I thought the X2HR was more V-shaped than measurements suggest it is. But open-back in that price range, ignoring the 'do nothing' option and buy another X2HR:
- Sennheiser HD 560S £99 - Feels like the obvious suggestion. Have a some brightness to it, but essentially a very neutral, very detailed set of headphones. Will have less bass than the X2HR. Bargain for what they are. I very much enjoyed them for gaming and they excel at FPS/competitive. However for music I was less enamoured with them (also the small bulges from the hinges on the inner ear cups rubbed my ears). But generally the 5xx line of Sennheisers is considered very comfortable by most. The newer HD 505/550 (& 490 Pro) are better tuned but are over £200.
- Beyerdynamic TYGR 300R £139 - Came out similar time to the 560S. Very good imaging, albeit the 560S probably do some things better (separation, detail). Classic Beyer DT chassis so very comfortable. Downside of an attached cable. Will have more 'boomy' low-mids than the x2HR and 560S. Personally I prefer these to the above, but I might be in the minority there. These are much smoother than the classic DT 990 Pro in the treble region and to me a better tuned DT 990, albeit some people like those.
- Audio Technica R30X (£80?) / R50X (£140) - I've never owned these, but both have been very well received. Might have some brightness like the X2HR/560S. Very lightweight.
- EPOS x Drop PC38X - (£150) Headset, but fantastic tuning. Just a very nice sound, even if they aren't technically the strongest. Issue is they are a sod to get hold of at their RRP in the UK.
- Fiio FT1 Pro (£180) - Planar, well received. Not sure how good these are for gaming, but imagine they should be solid.
- Beyerdynamic DT 900 (£200) - Again smoother than the normal Beyer house sound. They often get recommended for FPS/competitive becuase they are again very neutral.
