only 34" ultrawide, was looking for bigger, but my upshift recliner seat has snappedWhat size is your monitor
Do you find the pedals work okay without a heel rest? I'd read on Reddit about the pedals being tall and somebody struggling to press them (Not sure what size feet they hadi didnt bother as had a step uo and rig had own deck, u can just about see in pic.
yes you will unless you race in clown shoesDo you find the pedals work okay without a heel rest? I'd read on Reddit about the pedals being tall and somebody struggling to press them (Not sure what size feet they had).
I've got size 12 feetyes you will unless you race in clown shoesseriously though you will need a heel rest, i already had a Simforge Base Plate, as adjustable
You maybe on thenI've got size 12 feet
I've got size 12 feet and I would recommend getting the heelrest. its only a few quid more if you order it with the pedals.I've got size 12 feet
Do you have the base plate? As you say it's only £60 I'm not worried about the cost, it's the usability. Looking online the pedals are bolted down on to the plate with cap head bolts and nuts. The nuts are under the plate, I'm unsure how this will mount to my GT Omega Prime rig.I've got size 12 feet and I would recommend getting the heelrest. its only a few quid more if you order it with the pedals.
if you decide you want it later then it will be more expensive as you'll have to pay shipping on it.
perfect size imo. just so long as the monitor is very sloe to the wheelbaseonly 34" ultrawide, was looking for bigger, but my upshift recliner seat has snapped
it have to be now as new seat needed, just cant make up my mind between 3, certainly not be using upshift againperfect size imo. just so long as the monitor is very sloe to the wheelbase
I ended up going through Amazon as someone had pointed out here. Took around 1 week to arrive as I think it still came from China.I've been thinking about ordering these, did you order direct from Simsonn, any import fees, etc?
I was going to order the two pedal silver set because I'm clumsy and would have no paint left after install![]()
What seats are you looking at? I've got a GT Omega XL RS V2. it's okay, comfy enough, but there is flex in the seat back, think I'll buy a car seat next time, now that I know what I'm mounting to.it have to be now as new seat needed, just cant make up my mind between 3, certainly not be using upshift again
I had them with the baseplate yes, you would have to bolt the pedals to the plate then use t nuts and bolts to secure the baseplate to your rig, you might need some spacers under the pedal plate.Do you have the base plate? As you say it's only £60 I'm not worried about the cost, it's the usability. Looking online the pedals are bolted down on to the plate with cap head bolts and nuts. The nuts are under the plate, I'm unsure how this will mount to my GT Omega Prime rig.
Got some test drives last night. Went with the red default elastomers and set the Simsonns to 45kg in the app. Jesus Christ, I couldn’t achieve 90% in game consistently and was more like 50% which wasn’t helping. Couldn’t take corners anymore
Have I set it up wrong or does it take a while to get used to load cells at first?
No but I’ve been thinking of getting cheap swim shoes. Been fine with socks with the stock t300rs pedals.Do you wear shoes out of interest? My load cell is around 90kg and I run it at max
