** BE QUIET LIGHT BASE 500 LX MID TOWER CASE AVAILABLE TO PRE-ORDER **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hey Gang
Today we are announcing the start of pre orders for the brand new dual chamber chassis from Be Quiet!
The Light Base 500 is a clean aesthetic, dual chamber case with an angled intake at the front panel that allows the system to be placed close to a wall without interfering with airflow performance.
The case comes with a vertical mount hardware pack for system builders who want to mount their GPU in a vertical configuration but does not include a riser cable. (the official Be Quiet Riser cable will be live tomorrow under part code CAS-BEQ-06496)
The case has the benefit of back connector support for clean cable management as well as plenty of room in the roof of the chassis for a radiator that wont risk clashing with your motherboard heatsinks.
The case arrives in two flavours.
be quiet Light Base 500 Midi Tower Case - Black
Comes with the base chassis and accessory pack but includes 4x premium Pure Wings 3 120mm PWM fans (front intake fans are reversed blade) for silent operation and low key looks.
be quiet Light Base 500 LX ARGB Midi Tower Case Black
be quiet Light Base 500 LX ARGB Midi Tower Case White
The LX variant comes with the base chassis and accessory pack as well as 4x Light Wings LX PWM fans (same reverse blade config as the non RGB version) for if you fancy some lighting in your system.
Pre orders are starting today and I am expecting we will have inventory on hand within the next 2 weeks.
The Be Quiet! official riser cable is also now available on the OcUK store.
We have stock landing on this line at the same time as the cases for those who have pre ordered and want to use the VGPU function on the case
Available to Pre Order Here
Hey Gang
It doesnt look like they sell plain black reverse air flow fans , so you cant install any matching ones in the , plain black variant at the bottom of the case
