——The Official Battlefield 6 Thread——
Beta was good but this release was typical Ea/ dice **** up..
carn't even kill people close range and at range,,hit reg is fubared....
This is not even close to bf3/bf4/bf1.
zia
well bf3 you was lucky to even play for the first two weeks with the web based server browser half our clan had serious issues
Hit reg problems and jitter issues
  • Like
Reactions: ne0
Caved and bought last night for something to play until Arc Raiders at end of the month :D
Runs like a dream all maxed, without frame gen 140fps & with it on its 200+
They're a bit tight with ammo aren't they? Seemed to run out very quickly. Need to put some more time into it as not played a Battlefield properly since BF1, was like a rabbit in headlights when first loading into a game last night :cry:
What game mode is everyone playing the most?
This game reminded me how much I love BF4 and went back to that, glad I played the beta extensively and didn't purchase.
Reminds me of how much I want to love BF4, but run into endless things which detract from the experience, half-arsed coding resulting in bugs and glitches and "netcode" which just makes it up as it goes along, as well as the cheating. I jumped into a game of BF4 just now and the "netcode" as going my way and I was at like 27-3 in a couple of minutes or so then I was struggling to land shots on anyone and ended the game barely positive for KDR with around 40 kills total after another 30-40 minutes :(
I was playing Domination, and every time I tried to kill this low rank player I was instantly killed. At one point I was hiding in the bushes covering a corridor, and he came from the corridor and he slid and snapped directly to my position.
Knew he was cheating :mad:
- EA came back with action has been taken against this player
I've already come across at least one obvious cheater, as well as a couple of others who I suspected.
Hopefully, their accounts won't last long, which will put them off buying key after key at the current price.
Don't get why more companies don't adopt Valorant/Riot Games anti cheat software.
BF6 has a similar implementation Javelin (Vanguard and Javelin can even have compatibility issues with each other) - but like with Valorant it doesn't stop determined cheaters. Companies are a bit wary of adopting Vanguard due to the link to Tencent and hence the Chinese.
Hopefully stopped the drone glitch
They never stopped the similar MAV exploit in BF4 so wouldn't get your hopes up :s (albeit it isn't the same Dice as made BF4).
If you're playing Assault, you carry two primary weapons which your ammo allowance is split between. Take off the 2nd primary (I think it's a Shotgun), swapping it for a gadget, and all the ammo allowance goes to the main primary instead.
On the ammo side not too much problem, there are always bodies lying around. Pick up a different kit, have fun
I decided to be clever yesterday and picked support kit off the ground, dropped an ammo box
Seems I found a bug, box was not resupplying me, whether I kept that support kit or switched back to original assault...
If no one has already mention, in assault the ammo is split over the two weapons (rifle and shotgun) unequip the **** gun for a gadget and you have plenty of ammo.
Cheers for the ammo tip I didn't know it was split :D
It was quite fun having to scurry around and find a dead body for their loadout, but I still thought only 3 clips worth was a bit tight as you go through those in no time!
