Hi, are you looking to future proof for when you do have fibre and possibly for cctv too?
I’m mainly asking because a lot of systems like Blink you can just get a Wifi blocker which makes them not void as well as just putting hard connections into rooms is only a temporary solution because even if you get full fibre, it won’t solve your Wi-Fi issue as you’ll still have poor connectivity for everything else that doesn’t use a hard wire, I don’t know if you’ve seen any of my information on social media but specialise in Networks where it does both hardwire and wireless so that would be the ability to put a network in which can do both or give connectivity that would be the same as a hard wire, they even do access points that can be mounted in the rooms that have hardwire ability but give out Wifi the system can also do CCTV with hardwired camera cameras so it would stop any vulnerabilities to do with Wi-Fi cameras and you wouldn’t have to change batteries constantly. Hard wiring is definitely a solution for specific devices but then when you start looking at connectivity as a whole you’ll then only solving 40% of the issue.
It’s just questions that I ask just in case as I wouldn’t want you to spend money on something now and then not know there’s other things out there or things that you would want to think about in the future.
The problem is the early routers that deal with normal broadband speeds are built for high amplification of the signal because they’ve not got enough Speed to share around, the minute you get higher speed The Wi-Fi speed will drop to nothing because it’s trying to give a higher speed, which is a shorter range.
As well as if you ever do in the future want to have a proper CCTV system and then having a specific point where everything goes to that can work on the same Network would be a lot more useful to you than having to have two separate networks installed.
It’s just I’ve been to so many jobs where I’ve gone back to upgrade in the future when I’ve advised and then had to take out a lot of things to replace with other things or different layout because of a change in the Network or an upgrade of services so I always try in future proof or think of what you may want or need in the future.
The best thing for quoting for either method would be to physically visit and have a look where you were looking to have things and the layout.
