Anyone had any issues with the latest update for the U6 series? Again, the community forum seems to be going into meltdown a bit!
Need to mention what release train you are on?
Official
RC
EA/Beta
The latest officialNeed to mention what release train you are on?
Official
RC
EA/Beta
The latest official
I've not updated, just asking if anyone has?
So my U6-Pro updated automatically - even though auto updates are turned off?I'm using U6 Lite in a mesh mode and have not seen any issues.
UniFi Network Application 10.0.140
Overview
- Improved the WiFi, Hotspot, Network, and Internet settings user experience.
- Improved Official Network API.
- Extended scope:
- Devices - GET unadopted devices, adopt new devices.
- Firewall - Create and Manage Firewall zones, Firewall policy APIs coming soon.
- Networks(VLANs) - Create and Manage VLANs.
- ACLs - Create and Manage ACLs.
- Basic supporting APIs.
- Retrieve country list.
- Retrieve application list (DPI apps).
- Retrieve WANs.
- Improved API filtering options and error reporting.
Improvements
- Added Stats option to Port Manager when viewing All Ports.
- Added Remove and Pause actions in the Policy Table side panels.
- Allow IPv6 Interface Identifier for Zone-Based Firewall.
- Allow selecting "Any" and Public IPs for IPv4 ACL Policies.
- Allow searching the System Logs by VPN Client names.
- Improved Channel AI animation when channels are being improved.
- Improved application stability.
- Improved validation for QoS policies.
- Improved the Topology page filtering.
- Added Vendor and Device type filters.
- Improved the Ports Filtering user experience.
- Improved the unavailable channel display in the AirView section.
- Improved the Graph filtering user experience in the Dashboard.
- Improved the side panel user experience during sessions.
- Previously opened side panels will automatically re-open when re-visiting sections.
- Hide Activity Logging Settings when they are supported by the Control Plane.
- Removed the Legacy Web UI.
Bugfixes
- Fixed an issue where VPN Client Disconnect events were missing in rare cases.
- Fixed the inability to create SD-WAN configurations in rare cases.
Additional information
- Create a backup before upgrading your UniFi Network Application if any issues are encountered.
- See the UniFi Network Server Help Center article for more information on self-hosting a server.
- UniFi Network Application 7.5 and newer requires MongoDB 3.6 and Java 17.
- Version 7.5 to 8.0 supports up to MongoDB 4.4.
- Version 8.1 and newer supports up to MongoDB 7.0.
- Version 9.0 and newer supports up to MongoDB 8.0 and Java 17/21.
- UniFi Network Application updates may cause your adopted devices to be re-provisioned.
- Existing UniFi Network Applications must be on one of the following versions to upgrade directly to this version:
Code:10.0.140 and earlier 10.0.x versions. 9.5.21 and earlier 9.5.x versions. 9.4.19 and earlier 9.4.x versions. 9.3.45 and earlier 9.3.x versions. 9.2.87 and earlier 9.2.x versions. 9.1.120 and earlier 9.1.x versions. 9.0.114 and earlier 9.0.x versions. 8.6.9 and earlier 8.6.x versions. 8.5.6 and earlier 8.5.x versions. 8.4.62 and earlier 8.4.x versions. 8.3.32 and earlier 8.3.x versions. 8.2.93 and earlier 8.2.x versions. 8.1.127 and earlier 8.1.x versions. 8.0.28 and earlier 8.0.x versions. 7.5.187 and earlier 7.5.x versions. 7.4.162 and earlier 7.4.x versions. 7.3.84 and earlier 7.3.x versions. 7.2.97 and earlier 7.2.x versions. 7.1.68 and earlier 7.1.x versions. 7.0.26 and earlier 7.0.x versions. 6.5.55 and earlier 6.5.x versions. 6.4.54 and earlier 6.4.x versions. 6.3.51 and earlier 6.3.x versions. 6.2.26 and earlier 6.2.x versions. 6.1.71 and earlier 6.1.x versions. 6.0.45 and earlier 6.0.x versions. 5.14.25 and earlier 5.14.x versions. 5.13.33 and earlier 5.13.x versions. 5.12.72 and earlier 5.12.x versions. 5.11.52 and earlier 5.11.x versions. 5.10.27 and earlier 5.10.x versions. 5.9.33 and earlier 5.9.x versions. 5.8.30 and earlier 5.8.x versions. 5.7.28 and earlier 5.7.x versions. 5.6.42 and earlier 5.6.x versions. Most earlier versions are also supported for a direct upgrade, going back to 3.1.0.
UniFi Network Native Application for UniFi OS
A specific application version that is only compatible with the UDM, UDR, UDR7, Express, Express 7, UCG-Ultra, UCG-Max, and UCG-Fiber (running UniFi OS 3.1.6 or newer).
- The UniFi OS update uses the application version required for your console.
- The manual update process via SSH requires you to use the compatible package. Incompatible packages will be rejected on installation.
- Older UniFi OS versions (before UniFi OS 3.1.6) on the UDM and UDR still use regular UniFi Network Application for UniFi OS.
Code:e0b8cc6b43b5d86cf5c77179175f3314 | UniFi-installer.exe 11d907af388731d364cb407496859206 | UniFi-Network-Server.dmg 463a2b15055a175b0744bf5f8fa627d6 | UniFi.unix.zip 4ea19ae386bd42eff7ef3c011a4cfb89 | unifi_sysvinit_all.deb 818ff6af07e892203dcc6fa3a549114f | unifi-uos_sysvinit.deb 29bfe4f30f7c0ff1463bf1335566f609 | unifi-native_sysvinit.deb 601df32736f41e40a80a3e472450a3e1 | unifi_sh_api ------------------------------------------------------------------------------------------------------------------------ 25b2ee0279940f3ef88b62ce004d7137e1a7f6f57402518f3d6369bcb8f15966 | UniFi-installer.exe ea4aa50ff6199e7e13e47949ade18fc1eaf8382da31c3dd64c8665d12231a5b6 | UniFi-Network-Server.dmg 1f5d6b61f271fbaebd26d23928c78fedaa0c5abe69099939426fe44dc870c6d3 | UniFi.unix.zip be0da84bc2954c12f92db3f5192947823503477acee3f0e230d0055863d8e87d | unifi_sysvinit_all.deb 68ce5e57e0f0f5694dee986c00721f00b46849f371f776361f9656a707e5887a | unifi-uos_sysvinit.deb 65785f30b273d3ed10dc774dc235b3d8d381dbe8851e474d945cc728d443d7cc | unifi-native_sysvinit.deb 1791685039ea795970bcc7a61eec854058e3e6fc13c52770e31e20f3beb622eb | unifi_sh_api
Already running itNetwork Application version 10 in Early Access, who's brave?
I have that in mine.Its in 'settings' for me:
I haven't, I'm just basic filtering.. Ironically the Cybersecure Enhanced 'nag' is dismissible..I have that in mine.
I wonder if it's tied to the CyberSecure Enhanced subscription. Have you also subscribed to it?
I subscribed, and I don't see it.I wonder if it's tied to the CyberSecure Enhanced subscription. Have you also subscribed to it?
Main thing I'd like to see in an update is the abilitiy to treat a VPN client like a WAN port, with associated firewall rules, port forwarding etc.Network Application version 10 in Early Access, who's brave?
