The roof will be laminated also, the rear window is the one to go for.
Are you sure? I'll have to check that!
when I bought our nissan QQ with a pano roof i asked whether it was a failure point for insurance or if autoglass would cover it if damaged as a window replacement .After a brief search google's AI says that the pano-sunroof it is indeed double laminated on the Seal and I can confirm that by looking at the etching present.
Change of plan then - the rear door windows are the target then because no one is fitting out the rear window because of it's rake.
Hopefully it never comes to it though!
so that kind of torpedo's my last comment.... but it still would not be the 1st pane I would try to break
. I suppose I assumed that it wouldn't be like a windscreen as it's not a windscreen. Assumptions huh! I thought it being the biggest window and being able to stand up once it's out would give the best chance of escape. Ah well, Daisy Duke it is then
.It was interesting when he asked a young guy if he would buy an ev, and the reply was no because he loves the torque of a diesel engine.
BYD Sealion 7 AWD: 690 Nm
Ford Mustang Mach-E GT Performance/Rally: 949 Nm
Audi Q7 V12 TDI - 1,000 Nm
torque curve on 200bhp id3 says a lot on overtakes V
unfortunately the newer cars with the more efficient 550 motor/280bhp&pre-conditioning not yet at my 20K prices (ford explorer seems to be approaching fastest)
Non-dcc car with higher profile tyres maybe another option for comfort too, after all replacing worn adaptive dampers probably not cheap , that, also combats local pot-holes.
the APP550 has a longer gear ratio. Those 550 Nm wouldn't have been able to be delivered to the road with a short transmission anyway. So, comparing the ID.4 APP310 vs. the ID.7 APP550, the APP550 delivers "only" 8.2% more power when starting off, not 77.4% as one might assume at first glance. From 3600 rpm, the maximum output of 210 kW is reached, which corresponds to 61.6 km/h for the ID.7.
Two we've been looking at recently from China, were the MG HS Hybrid+ and the Jaecoo7
A friend has the Jaecoo7 and he rates it, even with the less than perfect ride.
Also checked 2 from Korea with the Tucson and Kona, which are obviously miles ahead ATM, but I would expect the Chinese to be working on bridging that gap asap.
I've been considering the MG S5EV and the Jaecoo 5 EV. Both feel a really nice place to be, although the Jaecoo has some horrid shiny black plastic trim which annoys me. I think the MG wins on most things, but i do like the idea of ventilated seats in the Jaecoo. Slightly cheaper too.
It's a tricky mental balance for me right now
MGS5 EV ~€35k with almost every extra you could hope for and a reasonable range. 8yr warranty
Skoda Elroq 85 ~€35k gets me a 3mth old one but it's fairly basic spec which loses things like electric seats and doesn't feel as nice inside. It has around 15% more range though. Only a 4yr warranty (although 8 on batteries)
Price is pretty much the same, but the Skoda is tempting me. It looks better and you'd hope it'd last better over the long term i plan to own it for.
We, or should I say the OH was drawn to the bells and whistles that came with the Jaecoo7 and tbh the plastic didn't really bother both of us. Have seen and felt the same type in the new Porsche Cayenne's and can forget quickly enough once driving.
The Skoda has the name and good history, but as you say above...It could all come down to the warranty and how long you expect to keep the car.
I would probably go for the Skoda now and then look again at the Chinese offerings when looking again.
I get confused by the torque curves that show rpm. A EV motor full speed is more like 15-20k.one last thing - in the shower did the ev mention it's torque at the wheels that counts, hence the recent discussion on ID3 performance;
there is an interesting engineering explained discussion on how much torque is useful too.
e: hence revolution on ev gearboxes too
The ex30 has a pretty small battery doesn’t it? Circa 64kwh where as the VZ is 79kwh isn’t it? Either way the battery will be the limiting factor.Had a go in a mates ex30 twin motor yesterday. That things comedy how it picks up speed. But he says power from battery Drops off very quickly. Even at 80 % it’s slower. And 60% I think it’s about 1.5 sec slower to 60 which he finds really annoying as you never really have the full performance.
Yes exactly. But more than just size. Cells, layout etc. look at dewalt powerstackThe ex30 has a pretty small battery doesn’t it? Circa 64kwh where as the VZ is 79kwh isn’t it? Either way the battery will be the limiting factor.
the ap 550 comment I posted suggests that the gearing is what is limiting it's take of speed , to the merit of over 40+ oomph and economic lower revs at higher speed,I get confused by the torque curves that show rpm. A EV motor full speed is more like 15-20k.
The AP550 motor is much more powerful but the power limit to stop it crashing, snapping driveshafts etc and is why it doesn’t take off that much quicker than a AP310 car. Once over 40 it really goes but they are being safe on the low speed power even in cupra mode with gives 240kW. A bit frustrating but it’s prob for the best of general public
