Is anyone else having an issue with the overclockers shop webpage?
I cant search in chrome, or sort anything, it just doesnt respond/refresh - I've tried 2 different computers.
Microsoft Edge does work, I just dont like using it..
Try flushing the dns on your computers.
How to run ipconfig /flushdns
1.Click the Start menu or press the Windows key.
2.Type cmd in the search bar.
3.Right-click "Command Prompt" and select Run as administrator.
4.Click "Yes" if prompted to allow the app to make changes to your device.
5.In the Command Prompt window, type ipconfig /flushdns and press Enter.
6.You will see a confirmation message like "Successfully flushed the DNS Resolver Cache".
If that fails, power down your ISP router and restart it.
If that fails too try this in a command prompt (run as admin) :-
tracert www.overclockers.co.uk
once it is done it will say trace complete, if all went well. If it fails maybe an issue with your ISP DNS or cloudflare issue for you, like it thinks your ISP is causing a DDOS (A DDoS, or Distributed Denial of Service, attack is a cyberattack where a target server or network is overwhelmed with a flood of internet traffic from multiple sources.). If that is the case then just wait a couple of hours and try again later.
