, also used it when i was lazy to cool system with just water but you have to change the water every so often as no radiators in system to dissipate heat. Chillers can work well, but not so cheap to run. Better off just upgrading your PC's cooling tbh, you can get them to run pretty much silent unless under heavy loads.Put your PC in the other room then and get fibre optic HDMI / DP cables and some USB extensions that run on cat 5 etc.I am trying to move the heat and noise from my PC (it will be a new PC) from the room its in to another room.
After doing a boat load of research that where I am heading with this. I was kind of up to 3 loops. 1 for the PC leading to a heat exchanger, 1 to cool the heat exchanger from the large resevoir and the final loop for the aquarium cooler.Aquarium equipment isn't really going to be that helpful long-term. Chillers are expensive to buy and run. If you're wanting to transfer heat to a different room, your best bet would be a massive external rad, and depending on distance, resistance etc several D5 pumps each way to ensure flow.
I am trying to move the heat expelled from the PC case and the noise away from the officeWhen you say cooler are you talking a chiller or pump/both, as with certain chillers you need a pump also, ive used a pond pump before fed from a cool box with water and ice with good effect for benchmarking runs, also used it when i was lazy to cool system with just water but you have to change the water every so often as no radiators in system to dissipate heat. Chillers can work well, but not so cheap to run. Better off just upgrading your PC's cooling tbh, you can get them to run pretty much silent unless under heavy loads.
My current plan is to put a big rad in the attic along with a couple of decent pumps (hopefully quiet). Its a 3m (ish) lift. Pumps at the bottom to push. mavity would work for the other side.
My attic did reach 35.7 in summer (I have added a bit of ventilation since then) but I am not planning on any significant overclock. Even a 35 degree attic should keep a GPU & CPU at useable levels
Hmmm - never considered that idea. Would clear some space in my office too.Why not just put your PC in another room, and run extended cables to your monitor etc like Linus tech tips? Will save you a boatload of cash
3 monitors, mix of DP and HDMI. I think the DP is the 4K monitor, other 2 (2K) are HDMI
I would need to put the PC about 8 metres away. The 4K monitor at 180Hz/120Hz (I can't remember its been so long) might struggle
I am also concerned about adding extra latency to mouse, keyboard, USB, Screens etc. Is that even an issue?
) The cold water in the cistern cooled the radiator, and the occasional flush was enough to avoid the water heating up.)
