I had been thinking about an old PC build for a while and then i noticed this old girl pop up on market place.
Screenshot_20251016_081757_Facebook by Bean Beano, on Flickr
Screenshot_20251016_081803_Facebook by Bean Beano, on Flickr
20251015_212731 by Bean Beano, on Flickr
20251015_195910 by Bean Beano, on Flickr
It was the same case as my very first PC build which my Grandad built for me when i was about 11 years old around 98 i guess.
Turned out the guy was happy to post it.
The spec of it was
Soyo SY-5VD mainboard
Intel Pentium 166 MMX processor,
S3 Virge video card
32 meg ram (mix of edo ram and sd ram)
Quantum Fireball 2.6 gig hard drive.
Virge S3 PCI Graphics card.
Creative Soundblaster 16 ISA sound card.
3.5 inch floppy
40 speed CD drive.
Windows 98 second edition freshly installed
It turned up not long after and it would not post at all. I took it all apart gave everything a clean and removed the dirt and dust. After lots of messing about it seemed the pc had a mix of 2 EDO ram sticks and one SD ram stick. With the SD ram stick inserted it would only post odd times. Removing the SD ram the PC would boot up fine showing 16mb of ram. I tried cleaning the SD ram slots with contact cleaner and a tooth brush but nothing seemed to get the SD ram to allow the pc to boot.
I also noticed the CPU was running at 233Mhz not 166mhz which the seller mentioned.
20251016_211503 by Bean Beano, on Flickr
I thought maybe the stick of SD ram was failing so i bought 2 sticks of 64mb pc133 Sd ram to max the board out to 128Mb. With these inserted the pc is back to not booting at all.
20251027_201429 by Bean Beano, on Flickr
I wondered if the over clock was causing some issue with the SD Ram. So i tried to set the dip switches back to 166Mhz but 2 of the tabs broke off. So I ordered some new Dip switches, de soldered the damaged one and replaced with a new one. Set the dip switches and i am now back to stock CPU speed of 166mhz. But i still cant get the board to post with the SD ram inserted. Or if it does post it will not recognise the full amount of memory and it posts saying "memory test failure".
New dips installed, i had to cut down an 8 way set.
20251027_200501 by Bean Beano, on Flickr
Im wondering there is a Bios settings i need to change or if anyone has any other ideas? I am reluctant to order more ram sticks incase i have the same issues.
20251027_200910 by Bean Beano, on Flickr
20251027_200739 by Bean Beano, on Flickr
The plan for this PC was to load some of my old games and also do a few upgrades. I have now fitted a ATI Rage 2 Pro 3d card, a USB rear panel port connected to the header on the Motherboard so i have USB now. I also have another sound card but i havent tried that yet.
h6uqOaw7 by Bean Beano, on Flickr
jbKnGwtA by Bean Beano, on Flickr
Any suggestions on how to resolve my Ram issues would be much apprecaited or any tips at all on this build, i was thinking of a 120GB SSD with some sort of IDE to SATA adapter but ive not looked into that much yet.
20251015_195910 by Bean Beano, on FlickrIt was the same case as my very first PC build which my Grandad built for me when i was about 11 years old around 98 i guess.
The spec of it was
S3 Virge video card
3.5 inch floppy
40 speed CD drive.
20251016_211503 by Bean Beano, on FlickrI thought maybe the stick of SD ram was failing so i bought 2 sticks of 64mb pc133 Sd ram to max the board out to 128Mb. With these inserted the pc is back to not booting at all.
20251027_201429 by Bean Beano, on FlickrI wondered if the over clock was causing some issue with the SD Ram. So i tried to set the dip switches back to 166Mhz but 2 of the tabs broke off. So I ordered some new Dip switches, de soldered the damaged one and replaced with a new one. Set the dip switches and i am now back to stock CPU speed of 166mhz. But i still cant get the board to post with the SD ram inserted. Or if it does post it will not recognise the full amount of memory and it posts saying "memory test failure".
20251027_200501 by Bean Beano, on FlickrIm wondering there is a Bios settings i need to change or if anyone has any other ideas? I am reluctant to order more ram sticks incase i have the same issues.
20251027_200739 by Bean Beano, on FlickrThe plan for this PC was to load some of my old games and also do a few upgrades. I have now fitted a ATI Rage 2 Pro 3d card, a USB rear panel port connected to the header on the Motherboard so i have USB now. I also have another sound card but i havent tried that yet.
jbKnGwtA by Bean Beano, on FlickrAny suggestions on how to resolve my Ram issues would be much apprecaited or any tips at all on this build, i was thinking of a 120GB SSD with some sort of IDE to SATA adapter but ive not looked into that much yet.
