Last night I heard a big pop in the house and all the sockets went off. Had a look around but couldn’t see any obvious issues so unplugged things and switched back the fuse on the RCD. Walked around the house plugging things in and turning things on. Plugged in computer and saw the white light on AIO, the mouse light etc. I pushed the power button on the computer and there was a big flash and a pop of electricity. Fuse tripped again.
Am presuming it’s ‘just’ the PSU blown but what’s a safe way to troubleshoot?
The PSU goes straight to a wall socket. Accessories go to a reliable power bar. That said, when unplugged I noticed it had been plugged into the extension bar in (a possibly expensive) error - would have been for a week at least.
I couldn't smell any burning at the back of the PSU.
The cable itself (a c19) seems fine and the fuse appears fine.
My main concern is preserving integrity of data on the 3 x nvmes.
I’ve ordered a new c19 and a usbc nvme enclosure to arrive today. My plan is to extract the nvmes, check they’re functional on another computer (I assume it’s just plug and play for the two storage nvmes, though not sure what would happen if I attached a system nvme (which has stuff on the desktop) to an existing system?
If they’re functional then at least I can work in the interim while I sort out the PSU.
Computer is less than a year old. I built it and have had no major issues to date. The PSU and many other components were from OCUK.
I presume the PSU will retain some amount of power inside so I don’t want to touch it prematurely.
Parts:
9950x / ProArt x870e / ProArt 4080 x 2 / 96gb 4800 Dominator Titanium (2 x 48gb / T705 4tb / SN850X 8TB x 2 / Thor 1600 Titanium 80+ / ProArt PA602
What am I looking at in terms of next steps?
Take off the side panel (no tiles in sight…), look around for obvious damage, remove nvmes / gpus and try cycling power with new cable in correct wall socket. I have another PSU in a spare machine but it’s not rated for the amount of draw in the current build. Different brand as well so would need to completely recable which would be a blow - I’m self employed and in the middle of a video edit - am fairly sure there’s some recent material which is only on one of the nvmes, so am hopeful they’re not wiped somehow, but they are attached to the mobo which could have failed..
Bugger.
Parts:
Bugger.
 . And sometimes lessons get learned. Sometimes.
