E-ATX Motherboard in ATX case
10 Sep 2007
Hello guys
I have been eyeing up this motherboard to move to AM5: https://www.overclockers.co.uk/asrock-x870e-taichi-lite-socket-am5-ddr5-eatx-motherboard-mot-asr-03304.html
I want a board with two PCIe 5 16x slots, this is the cheapest. However, its E-ATX.
From what I have read the screw alignment is all the same as ATX. The implication being that provided the case has the physical space, it will fit. The caveat being there won't be any support for the overhanging bit, so would require more care when plugging in anything into that part.
My question is, is my understanding correct? I have an old Antec P110 case, which I'd be happy to reuse in this build, it seems to have bags of space beyond the end of the current motherboard.
You're aware that no AM5 board has two PCI-E full length slots with 16 lanes electrically, right?
Yes, they mirror ATX on the part that's the same dimension.
Yeah, but the Taichi doesn't look like it has any anyway.
I'd measure it, to make sure nothing snags.
No I wasn't aware of that, doesn't that kind of defeat the object then? Or is this only an issue for power and not bandwidth.
My plan was to give me the potential to have two GPUs for video editing and/or AI. Not now, but at some point in the future, when I have more money.
Power is an awkward one, I wouldn't like to guess. Though, boards that expect you to use multiple graphics cards (or are aware of the possibility) I'd expect to be capable of providing enough power to the slot.
Bandwidth, yes, that's an issue, but it depends on your workload and the specific card(s) used. The best that you'll get on any AM5 board is a 8/8 lane split between the two slots and I believe that's what the Taichi does.
I'm not sure if the reduced bandwidth would have any impact for those tasks. For gaming, it mostly matters only when the VRAM is exceeded. If you were to buy two cards that were electrically 8 lane, then there's no issue there.
Hmm, sound like I would be better to assume I'll stick to the best single card solution. I can choose a slightly cheaper motherboard and not need to worry about the E-ATX thing at all then.
Thanks for your replies, glad I didn't go off half cocked. There was a time when I would have been aware of this!
I had another though, re-reading Tetras' replies and doing a bit of research.
The motherboard I suggested above only has two 16x slots and nothing else (not counting the m.2) but the two 16x slots do this 8x8 thing. Does that mean if you stick any other 1x card (eg sound cards / Network card) in the spare slot it reduces the bandwidth to the GPU to 8x, or is only if there's another 8x/16x card in the slot? If so it seems like a design weakness.
In your scenario, it would reduce to 8x.
The board, with a 9000 series CPU, forgiving any m.2 will provide 16 lanes.
So that’s either
PCIE1 at x16
PCIE1 at x8
PCIE2 at x8
If you were put a nic or sound card in PCIE2, the GPU in PCIE 1 will drop to x8, the other slot will have x8 even if you put in a x1 or x4 expansion card.
Gone are the days of PLX chips on motherboards, complimenting CPU lanes.
The real question here would be are you goi g to fully maximise even x8 PCIE Gen5 lanes if running 2 GPU’s. If so, you’ll need to go thread ripper or the like to provide you with the number of lanes you’d require.
Yeah, is a bit of a 'mare with modern boards if you want to use multiple slots, they really don't want you to.
The Creator used to be good with this (slot config), not sure about the current gen though. It is also still subject to the same CPU/chipset limitations, so you won't get extra lanes.
Awhile back there were boards with a PCI-E 1 lane slot positioned above the primary graphics, which was handy for wifi, sound, etc, but M.2 slots seem to have ended that.
That’s going to depend on the topology and how the manufacturer has configured the motherboard and if the BIOS has any bifurcation options.
Edit: Depending on the performance of the card/cards you want to use, 8x PCI-E gen5 (32GB/s) could offer plenty of bandwidth. The lower end RTX pro cards are 8x and they offer near 25 tflops. Nvidia don’t move to 16x until close to 50 tflops.
It’s starting to make a bit more sense now, I was wondering what the point of the extra lanes on the x870E was over non E if the boards don’t support devices, but it looks like the extra lanes are gen 3 or 4 PCI-E.
There does seem to be some boards including B850 which have extra 1x or 4x slots, which I guess might be better if I knew I was going to use them. I suppose I need to make the decisions based on whether there’s more chance of dual gpu or other misc expansion cards.
Yeah, there's no PCI-E 5.0 from the chipset lanes.
Ryzen AM5 CPUs have:
- 16 PCI-E 5.0 lanes for the graphics (can be split to 8/8).
- 4 for a PCI-E 5.0 M.2 slot.
- 4 more, which are often used for USB4 on X870/X870E or a PCI-E 5.0/4.0 M.2 slot on B850.
Having looked around, more or less settled on this this:
https://www.overclockers.co.uk/msi-...t-am5-ddr5-atx-motherboard-mot-msi-05545.html
Seems like the best combination of lanes etc and is a good colour scheme for the other parts I had my eye on. I saw the other thread about Asrock and have had trouble with ASUS so prefer Gigabyte or MSI anyway.
Unless you guys say this is bad choice, will get with 5950x non X3D as haven’t been gaming in a little while.
(will be upgrade from 3950x which has been mostly alright, want more RAM and don’t want to invest more in a dead end)
Edit: meant 9950x, I wouldn't need a new motherboard for 5950x
What will you be running in the PCIE slots?
3090 in the 16x slot for now, though that will be next thing I change (don't know when).
Won't need my 2.5Gb nic as the board has 5Gb. I tend to mess about with stuff. Have a decent sound card somewhere and SAS card and have a TV card on order (like it's the 90s again). Won't have them all in at once.
I mainly didn't want any of those cards splitting the bandwidth on 16x slot like the Asrock above would, even though it's unlikely to be real bandwidth constraint in the near future.
