I'm just looking for some pointers on testing PBO and CO stability on AM5.
It has been some time since I've tried PBO and CO at the same time (approximately 2019-2020) and since upgrading to AM5, I'm wanting to get back into it a bit.
As an example, I had +100Mhz on the CPU and -25 on CO which would pass OCCT over and over (Possibly wrong instruction set?), However testing on Ycruncher failed instantly.
+100Mhz -20 would do three passes then fail.
+100Mhz -18 has made 12 passes of Ycruncher so far. Maybe after a few more passes, I go onto Prime95 or Aida64?
Can I get some further testing tips i.e what should I be running for testing CPU, RAM etc
How many passes do you go for before calling it good? What settings do you use in each?
