a few updates for you guys. I won an auction for a new old stock BenQ cd writer still in the box for a tenner so i got that yesterday. When it turned up the drive was open slightly. I installed it but it would only open about 20mm and not fully close either. So i removed it, took it apart and couldnt get the tray opening mechanism to work properly. I thought it was going to need to be sent back but i kept going with it and eventually just gave it a good pull and it made a horrible sound but the tray opened and closed now. I put it back togther with not much hope it would actually work but it works great. its a really nice quiet drive and the tray is really smooth! The drive the PC came with didnt seem quite right when i tried some cd's in it. I also added the cd audio 4b pin wire from the drive to the sound card as it was missing from the old drive.
Cd drive swapped over.
4 by
Bean Beano, on Flickr
I also got a 120gb ssd hard drive, drive tray and IDE to SATA adapter. Ive fitted the drive in the tray and put it inside the case but i havent connected it up yet to load windows on. i thought i would wait until the ram came which i ordered.
SSD installed ready for when i get chance to sort a win 98 SE install cd.
5 by
I had seen a post about someone with this motherbaord or maybe a similar one installing some higher capacity ram and the board would not see the full amount but it worked ok. I thought it was worth a chance for a fiver and bought this set of 2x128mb sticks.
6 by
I put one of them in without the edo ram and it posted showing 32mb, woohoo! so i added the second stick and it went up to 64mb! great stuff. Got lucky there! I also ordered a set of 2x16mb edo ram sticks and a set of 2x 32mb sd ram sticks. Basically if they were cheap auctions i thought i would just give them a go and hope i got lucky. I can either relist the other sets or maybe keep them for another build at some point.
3 by
1 by
I also found out why the internal speaker wasnt working, one of the wires was cut, maybe it got caught in the cpu fan. So i soldered that back togther also.
Ive also got a sticker coming for the case which seems to be taking a while which should finish the case off a little.
Ive got some games installed so far and these are running.
Carnage
Doom
Doom2
Jazz Jackrabbit 2
Duke Nukem 3d
Duke Zone 2
Duke Xtreme - not fully tested yet
Outlaws.
A few more i plan to try are
Wolfenstein and spear of destiny
Rise of the triad
Star wars dark forces.
Various SCUMM adventure games like day of the tentacle, indiana jones - fate of atlantis as i never finished this when i was a kid. Sam & max, Full throttle, the dig ect
Im sure there will be others.
I might also put the CPU back to 233mhz eventualyl but i will see how it performs first as i might not need it any quicker.
