- 29 Sep 2010
- Cumbria
I have used a template for years which I have hacked to bits to suit what I needed it for. When trying to upgrade to 8.2 it breaks to critical error. I have used it on multiple sites and I have to do them all.
I have been trying to find something similar to build from but they all seem the be designed for using poxy page builders, scss or both.
I have been trying to find somewhere online that may be able to convert the code used as a template for my current sites so that I can rebuild them all the same way. I only want the basic site done and the rest I will hand code again for any changes I need.
Can anyone think of somewhere where I could upload the files form my template to make them compliant from 7.4.
If not, can anyone recommend a simple template that is not reliant on scss or page builders. Needs to be woocommerce compatible too.
Thanks.
Thanks.
