Talk to me about tripods
6 Nov 2002
Looking for some advice based off your experiences etc, I mainly take photos of static cars at events or locations such as C&M. With this time of year the light seems to be very limited so thinking about getting a tripod. This is my first camera etc so I'm definiately not a seasoned photographer :cry:
I don't want anything that's super heavy/takes ages to setup, current camera/lens is an A6700 with a Sigma 17-40 so not that heavy. If you were going to purchase a tripod now, what would you get and why?
I agree with the comments about using a monopod instead of a tripod.
But, if you insist on a tripod then the rule about selecting one is that you can have any two of light, stable and cheap. My favourite compromise is the Sirui ET-1204 but tripod choice is like belly-buttons - everyone has one.
With where you're shooting and what you're using I'd shoot handheld and have a polariser on hand to cut reflections/glare.
I have a Three Legged Thing travel. It is quite light and compact but I seldom use it. It does help with landscape as it slows you down and makes you think of composition.
From my experience people usually get in the way, so a tripod would be more of a liability. Couldn't you just bump up the iso?
It's what I've been doing at the moment but only goes so far depending on location/light available etc.
if you’re at busy events full of people and weight is an issue, you might be better off with a monopod instead,
Thanks, for the comments about monopods. Will keep that in mind, I don't mind carrying something around but looking at what's available on LCE/Wex there's a big difference and I suppose some are focused more on serious professionals.
Looks like I might have to travel to get to a decent store with kit I can try out. My local LCE is quite small and has limited stock.
I already use a CPL, the issue is lack of light (unless I bring my own).
  • Like
Reactions: And
For your type of use, especially with such a lightweight body and lens I'd recommend something small and lightweight that isn't a pain to carry around and you can quickly position in seconds and doesn't have a large footprint when the legs aren't fully extended. At car shows, the chances of it getting accidentally kicked or bumped into could be quite high.
I have two tripods.
An aluminium Manfrotto one which is very sturdy, very heavy, but doesn't move at all even in blustery conditions. It's about 15 years old and still works perfectly. It extends to over 1.8m high with the central column extended.
Recently I acquired a lightweight Slik sprint pro tripod as part of a package deal with a camera, lenses and some other bits and pieces. It's lightweight, takes seconds to set-up and folds up quite small. I wouldn't trust it with a heavy body or lens or in strong winds, but again it does the job it's intended for. I used it for the first time in anger shooting stills) at a Fireworks display last weekend alongside a second body on my Manfrotto tripod (shooting video).
I have a Manfrotto Monopod which I use mostly in the summer, the mount is pretty secure so you can leave your camera attached to it and just carry it over your shoulder. In the winter I use a Manfrotto 190 tripod which is very fast to set up and very stable. Had both for very long time and very pleased with both of them.
Manfrotto spare parts are readily available too so may make a decent second hand buy.
