As always, cheers for all the help on this thread folks!
I managed to get a second hand 5700x3d which I've fitted today (bit of a faff getting reaquainted with unseating cpu coolers & isopropyl alcohol but got there in the end!)
I've also just had the RX9070XT delivered, which I intend to fit tomorrow. It's massive compared to the 3070FE it's replacing so that's going to be fun. I was just watching a youtube guide for fitting that card and have just noticed it's powered by dual PCIe cables, which isn't an issue because the RM750 PSU i've got is modular, but i've just checked and I've not kept the spare cables in the base of the tower - hoping they're up in the box in the loft which I'll have a look for tomorrow, but if they're not, will any 750mm 6+2 PCIe cable fit this PSU or do I need to buy a corsair specific one? I'm assuming there's no variants around that would have a single connector going into the PSU and split to 2 connectors to go into my new GPU?
The 3070FE only needed a single PCIe to power it, so will need to get to the PSU to sort that regardless.
Cheers in advance
Good choice, Warzone loves X3D CPU's and AMD GPU's, and last I checked Battlefield is kinda similar.
CoD loves AMD GPU's so much that the 9070XT actually competes with the 5090, which is pretty damn hilarious given it's a £550-600 GPU vs a £2000 + flagship.
