- 5 Nov 2025
- london
Hi all, new here. Found a few threads that talked about Adguard home and as this is a UK forum, should make it easier.
So, simply put, has anybody got a Sly router (sr203) and AGH to play together.
I'm trying and losing my rag trying to setup and run AGH on my first newly built NAS/Home lab with Truenas OS.
Sly being sly, things are locked down so cannot use DNS, thus has to be DHCP but I'm struggling.
I'm stuck with the whole static ip address prompt. My Truenas is setup with a static address (which I believe is the meaning).
I cannot only disable the Sly DHCP via the config edit and upload but everything just tanks.
I then have no DHCP in AGH (which I do enable), sly router is rebooted but nothing.
I have read about people people buying new routers to replace the sly one, but that adds more expense, plus the whole option 61 thing some discuss is a required, plus I use the landline phone connection so theres that too.
Anybody had any succcess, some tricks or advice. I've tried pi-hole too, same block?
Please & Thanks
Please & Thanks
I hope you feel better!
