- 29 Dec 2012
- England
Hi, I was changing some M2 drives around on the mobo and after putting the CPU cooler back noticed an issue and needed to remove it to check something.
It is an amd CPU that drops into the motherboard slot and is then secured in place with a lever / latch.
My issue is that when the CPU cooler was removed, the CPU was stuck to the base of the cooler and placing it back and then the lever had no effect.
The PC does not boot but could this be down to the cpu problem above ?
The GPU is very old and was trying to work out if there is likely to be an issue with the motherboard or CPU.
