Internet dropouts monitoring options.
27 May 2003
Morning all.
For quite a while now our fibre internet has occasional random drops outs on our tech (phones, tablet, laptops etc) then kicks back in 5-10 seconds later. They will drop out a the same time if they're in use.
What's some decent free software I can install on a pc that's wired to the router so I can monitor any connection issues 24/7 for a while, to see if it's the router or WiFi signal interference?
Did a router reset but no luck.
Did the usual Google search but there are a plethora of software options and this really isn't my bag so I seek guidance!
TY!
Smokeping.
Also set up Thinkbroadband to monitor from external to your WAN port.
If your PC is wired, neither will tell you if it’s wireless congestion so look at WiFi scanning apps such as WiFiman.
Smokeping.
Thanks very much. Had a quick look at those and will see how it goes!
