Too save a long story my old pc failed built in 2017 and im looking to update. New computer aim is it needs to be as powerful or faster than old build and using as modern components as possible. I plan to reuse powersuply but the rest of the build will be from scratch. Motherboard will need to have on-board graphics as I like the safety net if my gpu fails as the pc can still boot from on-board which I currently cant do so im not sure if the gpu was the issue.
My old configuration
Mb: Asus Rampage VI x299
Cpu: i7-7820x
Gpu: Evga 2080ti ftw3
Ram: gskill 16gb kit.
Some notes
Old build was built for overclocking. The new build will not be overclocked.
Im looking to build as cheaply as possible but willing to spend what is required if there is a good justification for doing so.
New build will initially be run on-board graphics unless my new system will work with old gpu. In which case I will add a new gpu in future if it doesn't work.
New build components required
Case
MB
CPU
RAM
Cpu cooling
I want to stick with intel/nividia brands. The new build will also need to be m-itx mb based as id like to save space compared to old build.
I have an existing PSU/HD I intended to use both ssd/nvme drives and is psu evga 750 g2.
I have a rough idea of modern components but main reason for posting this thread is obviously some components are more reliable than others I hope to learn from everyone's experience which is the correct way to go. Thanks in advance for anyone willing to offer advise and I look forward to reading your replys.
Cpu: i7-7820x
Some notes
Case
MB
CPU
RAM
Cpu cooling
