No dedicated section for stream decks, so posting here in 'General' — feel free to move if there's a better spot!
Just wanted to share a recent purchase in case anyone else is looking for something similar. There aren’t many reviews out there yet, so hopefully this helps!
I’ve just received the MiraBox N4 Pro Stream Dock, and I’m genuinely impressed. It’s a solid piece of kit with great build quality and probably closest in function to the Elgato Stream Deck Plus, though there are some key differences worth noting.
Features the MiraBox N4 Pro offers (that Elgato Stream Deck Plus doesn’t — as far as I know):
Video:
Some images:
Software
- Built-in USB hub (Elgato’s is a £30 add-on)
- Haptic/vibration feedback on buttons and touchbar
- Customisable RGB lighting around the 4 knobs
- Full GIF support for backgrounds
- Supports more scenes and pages
- Can auto-switch scenes/pages based on the active app
- Software is very intuitive — almost a carbon copy of Elgato’s UI (which seems to be the standard format most stream docks follow now)
- Larger plugin ecosystem (thanks to a bigger community) — though MiraBox has a decent selection, and you can build your own if needed
- Elgato Marketplace offers free/licensed music tracks and sound effects — MiraBox doesn’t have a marketplace equivalent, though it does support built-in plugins like Voicemod
Video:
Some images:
Software
I am uneducated on the subject, so thank you for clarifying all that!
