Top gaming PCs with max budget of £2500 on OcUK according to AI
25 Jan 2009
UK
So I've been contemplating a new gaming PC for a while now (see my sig for my ancient specs). My PC can't do Windows 11 so I decided it is finally time!
I plan to treat myself so have a good budget (£2500).
I used this as a chance to experiment with the Comet AI based browser. I literally just went to OcUK store page, then asked the Comet assistant (Claude?) to take a look and list me off the top 3 choices for gaming PC.
It provided:
Refract IndigoHigh-endRTX 508032GB DDR51TB SSD£2,599.99
TechForge SakuraRyzen 9800X3DRX 9070 XT32GB DDR51TB SSD£2,699.99
OcUK Arrow LakeCore Ultra 7 265KRTX 5070 Ti (16GB)32GB DDR51TB SSD£2,500.00
OcUK FalconRyzen 7 7800X3DRX 9070 XT32GB DDR51TB SSD£1,899.95
OcUK EagleCore i9 14900KFRX 9070 XT32GB DDR51TB SSD£2,099.99
I then asked it to provide me with its choice for number 1 and it oddly listed an entirely different one not in the original table - the Gaming Katana
I asked it why it didn't originally list this and it said:
  • Sometimes "featured" or new lines (like Refract or TechForge) are given more visibility on summary landing pages, while other excellent options require deeper digging or filtering specifically for "best sellers" or top-reviewed systems.
  • The Katana absolutely deserves to be in your shortlist and is the top pick for balance of power, value, reviews, and upgradeability. If you want a "pick and go" best gaming rig under £2500, Katana is the one to get right now.
So what are people's views on this? Katana a solid option for price? It seems it...
Assuming gaming only and there's no particular reason for nvidia card (e.g. CUDA usage), then I'd rather have the Falcon than the Katana. You could ask OCUK if they will cover the extended warranty on the Intel CPU, I don't see the point.
Your AI needs a much larger model as the Refract Indigo is the clear winner at £2,399.99
Anything with a 13/14th gen chip should be dismissed unless dirt cheap.
You know the BIOS updates fixing 13th and 14th gen have been out for over a year yeah?
It provided:
I'd say go for the Falcon, but go for 2TB SSD.
1TB isn't enough nowadays, games are typically 100-150GB each
This is false.
There are still reported failures and there is no guarantee that any fixes have resolved long term problems. While Intel has offered longer warranties on the chips, it's frankly not worth the potential hassle for a gaming specific build on a dead platform.
