I’ve got some paranoia and was thinking of picking up a used 9070 (not XT) as they seem very cheap right now. My case can not accommodate very long GPUs so the dual fan 9070 models would be perfect for me, higher end just would not fit in there…
I never see too many people talking about the card though, as guess everyone just pays the small amount more for the XT. Are they worth the purchase? I’m a big fan of my current A770, but I don’t want to be stuck on this for 3 years if prices shoot to the moon again.
Even though I've had a few niggles with the latest driver and had to roll back to 25.9.1 I'm still loving this Sapphire Pulse 9070, highest temps are mid 50's with 50% max fan speed set, cant hear it, at least not over my 360 AIO fans. For performance its basically twice the speed of my old 3060Ti..
9070 vs 3060Ti Comparison: Time Spy
www.3dmark.com
9070 vs 3060Ti Comparison: Steel Nomad
www.3dmark.com
9070 vs 3060Ti Comparison: Port Royal
www.3dmark.com
I run DayZ maxed out with Medium AA and still get up to 250fps, not seen it below ~100fps on my 144Hz displays but Freesync keeps it smooth under that anyway.
I have GTA V installed just for the odd play but i keep it installed for testing mostly. I get average of 160fps with everything pretty much maxed out with Ray Tracing enabled too but GTA V does run pretty smooth which is what I aim for, smooth gameplay matters more to me than just high fps.
Open GL performance is very good compared to previous AMD cards, I get much higher fps in Second Life than I ever have with any card before this one, even in a club with over 75 avatars I get over 50fps, that would have been under 20fps on the 3060Ti
Considering I paid £445 for the 3060Ti in 2022 and £518 for the 9070 in 2025, more than double the performance is nice.
I'm very impressed with the cooling, noise and performance of this Pulse 9070 and it isnt that far off the XT model, I see people say the XT is around 10 - 15% faster but the price difference when I bought mine was a fair bit more than that.
I did initially put this 9070 in my Corsair 400C case, it just about squeezed in there with an AIO rad at the front but I ended up getting a new case, the Montech King 65 Pro, now I have bags room but airflow is so good now
The Pulse is 280mm in length fyi, I even measured it myself to verify, thats how much space you'll need from the bracket to the other end.
