Deleted member 280263
Hi,
I'm trying to help a friend out, she has a B450i PCI-E 3.0 board, it has 1 NVME slot, and 4 SATA's - currently populated with 1X NVME, and 1X SATA.
Being that it's B and not X series, would running 1 or more SATA's with current NVME, limit the GPU etc to less than PCI-E 3.0?
Or does it not matter with SATA, and instead it's only an issue with multiple NVME's, versus having say an X series motherboard?
This is way above my head, as I just use 1 NVME with my own machine, and always have.
Is the easiest way to find out, to simply check GPU-Z for what X the GPU is running at, i.e. 3.0 in this case? Then add more SATA devices, and see if it changes?
Does it make a difference whether it's a Bluray-RW drive or an SSD, as she has one of those she'd like to use alongside the SATA SSD, or does it make no difference, be it SSD or a RW drive?
Thanks
Thanks
