Upgrade time... from a 2018 Laptop!
Can't type for toffee
Don
14 Jun 2004
Newcastle U/T
Well my franken laptop is pretty much on its way out and looking for a new build, As you can imagine using this laptop since 2018 I'm somewhat out of the loop haha.
Laptop Spec is: ASUS FX5404GM
i7-8750H, 32GB RAM, 1TB Evo Pro, 1060 6Gb so at this point I think pretty much anything is gonna be an upgrade.
I really don't want a massive hulking black box sat on me desk so would like a smaller white case.
Screens already sorted, 2x 32" curved and I would like to game at 1440p
Looking around the goto seems to be a 7800X3D and a 5070Ti or 9070XT
Think I'm Gonna Grab a 4TB 990 Evo Plus and not worry about storage for a while.
Mobo: https://www.overclockers.co.uk/msi-...b850-micro-atx-motherboard-mot-msi-05943.html
Case: https://www.overclockers.co.uk/lancool-217-infinity-white-cas-lia-06169.html (or the mesh one if stock is delayed)
CPU Cooler: https://www.overclockers.co.uk/msi-...ce-all-in-one-cpu-cooler-3-coo-msi-03869.html
I would prefer an all white build but I'm not averse to just chucking it all in a non windowed white case tbh as long as its not hulking massive Massive case.
The cooler I've gone with above seems a solid little AIO for the money
I am a bit lost with RAM and PSU tbh
RAM I was looking at: https://www.overclockers.co.uk/cruc...0mhz-dual-channel-kit-whit-mem-cru-03115.html
But does the C36 hamper its performance?
PSU I was looking at 1000w and modular but other than that not a scooby
As for GFX , who's best for GFX warranties these days?
Not interested in OCing really just want summit I can setup and leave as I have done with this laptop and simply have it work.
Is gaming the most demanding task you do ?
Why don't you go matx case as well there loads that can fit big gpus and 360mm aio even a 240mm aio is more than enough for a 9800x3d.
Examples
Rams fine. And 1000w covers you for future upgrades i
£60 (incl. VAT)
£57 (incl. VAT)
£70 (incl. VAT)
£60 (incl. VAT)
ooh I thoudht I'd struggle with a proper size GFX and an AIO in a mATX, I'll have a neb.
Aye gaming will be the most it's pushed tbh
Black Friday mite see the best to grab a GPU , not sure if your in the know but mite get a heads up on GPU prices at Overclockers.
9070xt offers great value but the 5070ti has dls4 and multi frame gen so if ther close on price personally would lean to the 5070ti.
Check what games your playing to see if they perform better with AMD or Nvidia GPU.
Sapphire Pure is another option. I think it looks better (appearance, I mean) than that one.
Asus Prime and Phanteks AMP GH are both in stock in the 850 watt capacity, but I think only the AMP GH has white cables. They're second tier PSUs with 8 year warranties, but even though it (the platform) reviews alright, notable that the AMP is no longer a Seasonic.
Zotac is the longest (5 year, if registered within 30 days) and Gigabyte Aorus (only Aorus) the second longest (4 year).
I think the 9070/9070 XT are all 3-year (with OCUK, might not be elsewhere), but there's a warranty tab on the listings.
Zotac's Twin Edge is usually a compact model, if you're going with a tiny case.
If you go with the A3, there's a bunch of charts on their website and the compatibility depends on the PSU length and the choice of cooler.
With an air cooler (like freezer 36 or peerless assassin) or a 240mm AIO and a 140mm PSU (like Phanteks AMP GH) the GPU compatibility is very good (> 400mm).
If you use a larger AIO or a larger PSU, it shrinks to 334mm, but that's still big enough for most cards, like Sapphire's 9070 XT Pure.
@Tetras thanks mate :)
getting more complicated tho haha
I'm liking the look of:
as the CPU Cooler
PSUs I was lookgin at:
But if I go with the A3 Im not fussed about colour really as will just get the mesh side panelled one
Thanks for the mention of the size chart I'll have a neb of that now :)
I'll deffo look at the Zotacs too but I did see
and thought i looked a lot smaller than some others
Personally, I'm not sure I'm brave enough to buy a Gigabyte PSU after the early models went snap, crackle, pop.
The later reviews suggest Gigabyte has fixed the problems. It is overpriced though at £120, especially with just a 5 year warranty. Antec's (Seasonic Vertex derived) HCG Pro is £135 at OCUK and that's a top tier platinum-rated PSU with a 10 year warranty (Seasonic's equivalent gets 12).
The Edge: I'm not sure how that would work in the A3, or other compact cases, so couldn't recommend.
RMe: the later models have not got the best reputation and Corsair tends to charge way too much for these, when compared to their higher-end models.
MSI's Expert: I think it is in the middle. Most of the lower-tier 5070 Ti models are shorter than that card, but the higher tier ones are longer. E.g. the Strix is a bit longer and the Aorus master is much longer.
Reet thanks for the guidance chaps... I had my basket built and ready but then got side tracked and went prebuilt :eek:
9800x3d, MSI B650, MSI A30 AIO, MSI 850w PSU, 5080, 32Gb (awaiting 64Gb) 1TB (awaiting my 4TB)
So that puts my upgrade path at...
Cyrix M2, some random intel chip, 2500+Barton, 146 Opteron, 2500K intel, i7 laptop (11 series iirc), 9800x3d
There been a few ram increases, GFX card changes and bits n bobs along the way but I think I've made each last a reasonable amount of time
MSI b650 mobo are all pcie4 as far as I'm aware. seems an odd choice for a 9800x3d/5080 combo... probably wont effect anything tbh, but recent vid showed when vram got full on the gpu, it would shunt some of the work over to the pc ram, which ended up with slower frames on pcie 4 mobo's vs those with a pcie5 gpu slot..
can probably attest to this as was running a 3070ti/7800x3d on a b650 board outputting 4k...with dlss etc it was just playable, but image was very solf and my ram useage was alsways showing really high useage (guessing 4k texture overwhelming the 8gn vram on the card)...when i put in the 9070xt, ram useage plummeted
Yeah the one I was looking at was a B850
I am only gaming at 1440p as well so should have plenty overhead lol
This PC should do me til the robots take over
