Advice on upgrading from IPS 1440p monitors to single OLED
14 Apr 2007
Hi there,
I currently use Dell S2719DGF + S2721DGF monitors for work and gaming. They have served me well but I feel it's now time to make the jump to a single larger OLED and possibly 4k monitor.
Mandatory requirements:
32 or 34 UW
High refresh rate
Low response time
G-Sync/Free-Sync (currently use an AMD card but want both options covered for future use)
Luxury requirements:
4k
KVM
DP 2.1
I spent a bit of time looking through the forums, reddit, RTINGS etc. As a result, I've narrowed down to the following:
Dell Alienware AW3225QF - QD-OLED, 4k, 240Hz, Dolby Vision, G-Sync - £582
ASUS ROG Strix OLED XG32UCWMG - WOLED, 4k, 240/480Hz, KVM, G-Sync/Free-Sync - £823
ASUS ROG Swift OLED PG32UCDP - WOLED, 4k, 240/480Hz, KVM, G-Sync/Free-Sync - £823
MSI MPG 322URX QD-OLED - QD-OLED, 4k, 240Hz, KVM, G-Sync, DP 2.1 - £648
Gigabyte AORUS FO32U2P - QD-OLED, 4k, 240Hz, KVM, Free-Sync, DP 2.1 - £898
Dell Alienware AW3425DW - QD OLED, 1440p, 240Hz, G-Sync/Free-Sync - £614
Notes:
I was originally gravitating towards the Alienware AW3225QF, as it receives heaps of praise and comes in significantly cheaper than the ASUS and Gigabyte options. However, it lacks a KVM which will make switching between work and gaming a bit more cumbersome (admittedly I don't use a KVM at the moment). It's also lacking DP 2.1 which may impact future use? Curved also appealing.
MSI MPG 322URX looks like a great option on paper but I can't actually explain why it doesn't grab me.
ASUS PG32UCDP could be the one, but again it lacks DP 2.1 and it's close to £250 more than the Alienware AW3225QF. Worth it? Not sure.
I think any upgrade from 1440p IPS monitors will be night & day, but going from 1440p to 1440p might leave a sour aftertaste especially when there are a plethora of 4k options.
Thoughts? Recommendations? Anything else to consider?
Help much appreciated :)
Am I right in thinking that 4k 4th gen type OLED monitors are not generally available yet?
That is something that I would consider, noting you want minimum of 32"
The 4th gen being the ones using Tandem technology, seems impressive compared to previous gen
I'd stick with 1440p for gaming at 27"
Get 4K if you're getting 38"+
If it's for work as well I wouldn't consider the 1440p OLEDs. 4k doesn't need to be on 38"+ to look good, it looks great at 27".
They're alright for a bit of light reading, browsing etc. but I just find the poor text clarity on both QD-OLED and WOLED monitors at 1440p to be too distracting to use for work.
The 4k models are fine, both the 27" and 32" - and both QD-OLED and WOLED (although we don't have WOLED 27" monitors yet).
Realistically, if I'm OP, I'm probably going for either the AW3225QF, the XG32UCWMG or the FO32U2P - especially if I was moving to just a single monitor and the space to support a 32" screen.
The AW model is super well priced and Dell's support in the UK is fantastic. The Asus XG model is a glossy WOLED with that really nice 'true black' coating that does look insanely nice - although you are paying a bit more for it. The Gigabyte FO32 model is again, a fantastic monitor but also has some additional features that I'd definitely be taking advantage of like the cropped 24.5" mode, the KVM is great, DP 2.1 is always a nice thing to know you have (although I don't think it should be the decisive factor).
I don't think you can make a bad choice right now.
