You say metalic I think maybe I would say ozoney perhaps.I say 'metallic' hard to explain
Check the CPU socket for bent pins just in case.I powered it up again and I'm getting a post code of 00 which means cpu not being detected. I think the psu thermal protection cut in and when it cooled down it was okay again but for some reason the CPU got fried.
I will tomorrow. Thanks.Check the CPU socket for bent pins just in case.
Which motherboard is it ?I will tomorrow. Thanks.
It's a Gigabyte X870E aorus elite. I didn't clear the cmos before I started it the second time so I will do that tomorrow and try again.Which motherboard is it ?
Set a custom fan curve for the fans in the bios or if the cooler has its own software.Sorry I was blocked for sending too many messages. I am on the new system now and it is awesome but loud, my wife is not happy. I will need to detune it or get quieter components. Its the AIO I think that is too noisy. The smell of burning must have been because everything was new. I can still detect it if I sniff the PSU.
I'd change out the PSU if it's smelling. It's a ticking time bomb.Sorry I was blocked for sending too many messages. I am on the new system now and it is awesome but loud, my wife is not happy. I will need to detune it or get quieter components. Its the AIO I think that is too noisy. The smell of burning must have been because everything was new. I can still detect it if I sniff the PSU.
