No - please don't connect the ONT into a switch.I have converted my phone sockets to RJ45, What I want to do is put the router in the bedroom for better WiFi, is it possible to connect the ONT to a network switch?
Ok thanks so that's not going to work, as I have other devices.No - please don't connect the ONT into a switch.
You can however use the phone sockets, but it should be direct between the ONT and the Router with no other devices between
This will be the only way thanks, I was just trying to figure out a cheap quick way, I already have a swith in the bedroom that I use for my pc and laptop, I'm guessing it will be ok to connect the access point to the switch?Have the main router connected to the ONT, then use the converted phone sockets to put an access point instead on where you want the better WiFi?
This is the way.Have the main router connected to the ONT, then use the converted phone sockets to put an access point instead on where you want the better WiFi?
Yup.I'm guessing it will be ok to connect the access point to the switch?
Yes. But no.I have converted my phone sockets to RJ45, What I want to do is put the router in the bedroom for better WiFi, is it possible to connect the ONT to a network switch?
I'm puzzled as to what you mean by you have converted your phone sockets to RJ45. You did rewire all the running cables to Cat5e or Cat6, yes?
My router is in a different room and I just ran a Cat6 cable to the ONT. I can't imagine why you would want a switch in the way. It offers no benefits since the first the only thing connected to the ONT should be the router.
New builds tend to use cat5e or cat6 for internal phone cabling, but only terminate the required pairs. You can remove the RJ11 faceplate and replace it with RJ45, then terminate each end of the existing cable appropriately once you've figured out how they put it in. It's how I've got runs from the loft to my downstairs office and living room. Annoyingly they tend to be stapled in rather than run in any conduit so you can't use them to pull through fibre or better cabling (I doubt they'll install them 'nicely').I'm puzzled as to what you mean by you have converted your phone sockets to RJ45. You did rewire all the running cables to Cat5e or Cat6, yes?
Newbuild with plenty of phone sockets that will never be used, popped off the faceplate and converted them as the wiring is cat5e.I'm puzzled as to what you mean by you have converted your phone sockets to RJ45. You did rewire all the running cables to Cat5e or Cat6, yes?
Mine wasn't even properly punched down it's like they knew the phone sockets weren't going to be used lolI did the same with our new build (2022), popped the faceplates off and found it was just cat5e with only 1 pair wired up.
Easy enough job rewiring them all with RJ45 modules instead and gained a few extra ports![]()
