I have worked with many basement waterproofing systems over the years. The key point to know is that tanking and sump pumps are not the same. They are made for different problems.
Many people think tanking (Type A) is the easy solution. However, what is often overlooked is that tanking depends on good substrate preparation and strong long-term bonds. If the background is damp, dirty, or moving, the pressure will find a weak spot. Once that happens, water pressure just pushes its way behind the coating, and you’re back to square one.
This is why, especially in existing basements, tanking tends to fail more often than people expect. You don’t get a second chance with it. If it de-bonds, it’s game over.
The alternative is a Type C cavity drain system. This doesn’t try to hold back the water, it accepts that water will always find a route in and manages it instead. This is all about hydrostatic pressure. You line the walls/floor with a studded membrane, create a controlled drainage path, and discharge everything to a sump/pump system. It’s much more forgiving because it depressurises the water rather than fighting it.
BS 8102:2022 (the British Standard for basements) actually classifies Type C as the safest option for most refurbishment situations because you’re not betting everything on a single bonded coating.
In retrofit basements with any history of dampness, a pump system is typically the more reliable long-term option. You can still combine tanking with a cavity drain (many waterproofing designers do this for redundancy), but going “pump only” with a well-designed drainage layout is very common now.
If you want a more detailed breakdown of the difference between tanking and drained systems, these two guides explain it pretty well without being salesy:
And for the pump side, this explains how a sump setup integrates into a cavity drain system:
Worth a read if you’re mid-decision.
Newton has been around for a long, long time and is well recognised in the industry. The key is to avoid relying solely on tanking in an old structure. The risk of future pressure build-up is greater than many people realise. Happy to answer anything else if you’re weighing up options.
