DIY plastering - asking for trouble?
6 Oct 2004
Birmingham
Repairing the kitchen following a leak, have pulled all the tiles off the wall, and it's left the plaster in quite a mess, a few big holes and the skim coat has lots of patches taken out of it - while removing/replacing the tiles was part of our original insurance settlement, there's nothing on the scope of works about repairs to the wall behind if needed, so the insurance may well pay the extra to get it done properly...
...however, I'm getting a bit fed up of being let down by trades (so far I've had 2 builders, a gas engineer, plasterer and electrician fail to turn up when agreed or even have the decency to let me know they aren't interested), we've got the new kitchen coming in 2.5 weeks, and still need to paint before it can be installed, so unless we want to have our living room full of appliances, worktops & boxes of cabinets for the foreseeable future, it would be nice to get this done ASAP, so I'm seriously considering DIYing it.
It's not something I've done before, and I'm getting the impression that it's one of those jobs that seems a lot easier than it is, and if it's done poorly then a coat of paint isn't going to do much to hide any mistakes. I've seen there are a few varieties of easy skim stuff, which you apply with a roller and then use something like a speedskim to flatten out - anyone have experience of using these?
Or is it worth just resigning ourselves to keep looking until we actually find someone willing to turn up for the job, even if that potentially means into early next year?
Personally I would have a go myself. It will be difficult to get a perfect finish, but providing you can accept the imperfections likely from a beginner, then have a go.
I've not tried it myself. I expect the skill is in getting the plaster mix right. Watch a lot of YouTube videos beforehand.
Since it's a kitchen, most of the walls will be covered with cabinets, so I guess it's not going to be as obvious as a big flat wall in something like a living room or bedroom, and worst case scenario, if it looks awful, I'm back where I started with needing to get a plasterer in, the only loss being materials and a few hours of work.
I've done a little bit in the my old house, yes it isn't any where near as easy as it looks when a pro does it but it can turn out ok if you take your time, i just had to do more sanding afterwards to get it smooth and level enough but it turned out 'fine'.
I did a patch behind our fridge freezer so it was never going to be super obvious but i think it turned out ok.
I'm going to give Dalapro Roll Nova a go in my office. You roll it on to the wall with a special paint roller and skim it off. Lots of YouTube videos saying its pretty easy to use. I'm not expecting a pro finish, but hopefully I can get it good enough for me.
Yup, that's one I was looking at, with the other being Toupret Magic Levelling kit.
Have been given another recommendation for someone, who has so far given a vague "at the weekend/early next week" to come and take a look, but failing that I think I'm just going to give it a go!
I've used Knauf Proroll Light roll on plaster on a small wall under the stairs and was pleasantly surprised how well it went overall! Just used a medium pile roller to get the first layer on and smoothed it with a 600mm Ox Speedskim I had from another project. It was pretty decent here and the instructions say you should get away with 1 coat on a smooth/board surface but there were a couple of bits I wasn't happy with so lightly sanded a few areas then rolled a second layer on and it came out lovely. Painted it up after and you'd never know it wasn't "proper" plaster. Would absolutely use it again for other projects and touchups
Plastering is an art, it looks easy but getting a perfect finish is not. If you are retiling then this repair job becomes much easier. If you're covering it up you don't need a perfect finish.
We're not fully re-tiling, only to partial height* above the worktops (i.e. as a tiled splashback), and between hob and cooker hood
*probably... will see how this looks and go right up to the cabinets if it looks a bit crap!
Time. If you have the time, anything is possible. Do you have the required time to get a good enough job completed?
If I do end up DIYing, I shall post photos, hoping this latest guy turns up though, I don't particularly want to do it myself (especially if I can get the insurance to pay for a pro), but also don't really want to be waiting months until we finally find someone to actually do it!
I would start practicing straight away if there is even an slight chance that you may do it. The sooner the better.
Even knowing how to mix it to get right consistency takes a bit of practice. This is often overlooked when people talk about plastering.
