Haha no problem! They look similar to the gripit types so I'll have a look into them too, thanks!bull fix plugs sorry lol
It's a 1930s bungalow with brick wall that they have made a cavity for at some point for insulation I am assumingWhat do you mean there are studs and then brick behind it? It should either be a stud wall or dot and dab I think?
(the speakers in LG OLED are pretty bad)I already have a fairly expensive 5.1 system that I have spent a few grand on. Ive also just upgraded to a Denon x4800h and am waiting on a new center speaker. I'll do the front sides at some point next year and I bought an SVS-PB1000 in December last year.Bigger question is how many hundreds of £'s are you putting into the sound system(the speakers in LG OLED are pretty bad)
Ahh ok. Look into Corefix, made for plasterboard over brick and would hold an elephant to the wall:It's a 1930s bungalow with brick wall that they have made a cavity for at some point for insulation I am assuming
They look very similar to the ones that came with the mount, except they didn't come with the metal sleeve.Ahh ok. Look into Corefix, made for plasterboard over brick and would hold an elephant to the wall:
That's the magic! You hammer it into the plug and it braces the gap between the plasterboard and the brickwork (so you're essentially screwing directly into the brickwork) and the plaster won't collapse into the cavity when you screw in tightly.They look very similar to the ones that came with the mount, except they didn't come with the metal sleeve.
That probably sounds like the best option if they do them long enough to get them to the wall behind!That's the magic! You hammer it into the plug and it braces the gap between the plasterboard and the brickwork (so you're essentially screwing directly into the brickwork) and the plaster won't collapse into the cavity when you screw in tightly.
Mines been up a few months now using those fittings and it’s not moved at all. I decorated too after it had been up about 6 weeks and bracket was still solid to wall. I’ll admit I kept joking for first week that we would come home and to would be on floor but I don’t worry about it now. Mines a new build and internal wall so no bricks. I did find studs when putting a new socket behind to and running cables in wall, they were just not in right place. Tv so flush to wall also makes room feel bigger. It was on a stand before and sat quite far from wall.
