First Desktop in several years
28 Nov 2025
UK
Hello everyone,
I last got a desktop here several years ago and it is just starting to strain a little. I'm completely out of touch of what would be a good build for now and future proofed for, about 5 years (if possible).
My current build has 2x1 TB drives (first one SSD). 12gb Ram, RTX 2070 Super.
I mostly use the PC for gaming - mostly simulation and strategy games - but sometimes a FPS. I tend to use a lot of storage, quickly outgrew the past one with games, photos and music.
Timescale - Ideally before Xmas, but fine with after if needed
Budget - not sure what to expect. Aiming for about £2k - but not sure what is realistic
RAM - I sometimes need to multi-task. I'm thinking 16gb minimum, but more likely 32gb. Seems 32gb is more the norm now?
Storage - perhaps similar to what I had, 1x2TB (SSD?) drive for Windows/Games, 1x2TB for pics/music/documents, so needn't be as fast. Will take more storage on SSD depending on extra cash needed
Cooling - I don't think I work to excess, but current rig does whir a lot, so adequate cooling!
Other - I need it to have WiFi and Bluetooth. I have a two screen set-up already and don't need mouse/keyboard etc. Ideally, old school, and have a dvd/blu ray player (I suspect this makes me very old).
Previous was put together by Overclockers and it went well, so will likely go for that again.
May look at a new speaker set up. Currently, I have a basic pair on desk and subwoofer on the floor. Not much room on desk, so soundbar may work better. And anything smaller on the floor as it takes up a lot of room! But PC is the main focus, sound stuff can wait - as long as it all works!
Thanks for your help. Sorry for vagueness, so out of touch!
If you're going for another pre-build this isn't a bad bit of kit:
My basket at OcUK:
  • 1 x OcUK Gaming Falcon - AMD Ryzen 7 7800X3D - Radeon RX 9070 XT Gaming PC (SKU: FS-1FH-OG) = £1,880.03
    • Case: 1 x Phanteks XT Pro Ultra ATX Case Tempered Glass Window, Black
    • Processor: 1 x Build Stock AMD Ryzen 7 7800X3D Eight Core 5.00GHz (Socket AM5) Processor -
    • Memory: 1 x Kingston FURY Beast EXPO 32GB (2x16GB) DDR5 PC5-48000C36 6000MHz Dual Channel Ki
    • Cooler: 1 x MSI MAG CORELIQUID A13 240 BLACK ARGB Performance All In One CPU Cooler - 240mm
    • Graphics: 1 x *Build* Sapphire Pulse Radeon RX 9070 XT Gaming 16GB GDDR6 Graphics Card
    • M.2 Solid State Drive: 1 x WD Black SN7100 2TB SSD NVME M.2 2280 PCIe 4.0 Solid State Drive
    • Operating System: 1 x Build Stock Microsoft Windows 11 Home Advanced - Systems
Total: £1,880.03 (includes delivery: £0.00)​
I'd aim to buy sooner rather than later if you can, there's currently extremely high demand for RAM and it's seeing prices skyrocket while stock gets cleared out left and right.
You could save around £100 if you installed W11 yourself rather than having it included.
Appreciate your quick response. I will take a look at that. I've looked at the second drive, any issues with the Samsung 2TB 870 EVO? That would be mostly for pictures and music. Assume build is ok for WiFi and Bluetooth? Would this be considered a pretty decent build, i.e. should keep me going for a few years? I like AMD and the specs look good. Anything I could add or tweak if I asked them for a custom build? thanks again
If you're buying RAM and SSDs in the short term you should buy now before prices increase further. GPUs may also be affected soon.
Get a USB one.
I can recommend the SoundBlaster Katana v2 I use unless you're an audiophile.
Should be fine with the Evo.
According to the spec list, the build has both wi-fi and bluetooth.
If you're wanting a speaker upgrade and have the room, you really can't go wrong with Edifier:
My basket at OcUK:
Total: £187.97 (includes delivery: £11.98)​
This has been really helpful, thank you.
I probably shouldn't ask, but am I missing a trick with anything. If I added, say, another £500 to the budget - would there be anything I could/should change for a better system? As mentioned, I'm looking to future proof this for a while - so would the above spec be considered pretty high quality at todays standards. I guess for the sake of a few hundred now, I don't want something that may struggle a few years down the line. Thank you
My basket at OcUK:
Thanks for the speaker suggestions. I think I'm edging towards a sound bar as I have room under my monitors (currently my dumping ground for notes and papers!) but limited around the sides of the desk. The subwoofer is good, but the size of a small crate. I do want good sound as I play music through it, but it needn't be cutting edge.
I think that the rx 9070xt is a great value card and hardly slower than a more expensive 5080. (Just be sure to always active fsr4 on games).
