- 9 Dec 2009
- Bristol
Hi all, does anyone have any experience of using plastic ramps similar to these?
When working underneath I normally jack up each side and prop up with axle stands, but the Mrs new EV has very limited jacking points beneath, just the reinforced jacking points on the sills from what I can see.
The ramps linked above area rated up to 5 tons between the two.
I was thinking of putting these on my Christmas list.
Any thoughts?
2X Heavy Duty 5 Ton 2.5+2.5 Ton Plastic Car Ramp Lifting Ramps 33cm Extra Wide | eBay UK
2 x Car Lifting Ramp. Strong construction ensures long lasting performance. Load capacity: 2500 kg per pair. Extra wide design to suit larger vehicles. Material: PP. We will reply to you as soon as possible.
ebay.us
Any thoughts?
