Been running a Gigabyte 9070xt for a couple of months now. I wish it was quieter (my ref 3070 was silent in comparison). I've also had maybe 3 driver crashes in that time (which isn't too bad really). Other than that, really happy with the upgrade.
Could it not just be the fan curve rather than temperatures? The one thing I noticed across a few 9070XTs is that the default fan curves are really aggressive - so even if the card is around the 60 deg mark the fans are running at 45%.Might worth a cheeky undervolt. Try power target -10 and undervolt-40 to start you can go more aggressive if you fancy it. Your temps will come down quite a bit.
