Il check them out buddyOCUK have a great range of Ducky One 3 keyboard that come in all colours/configurations/switches.
They are very good keyboards.
Yer they look nice also. What model you got?Happy with my keychron
Nice that buddy had a ASU’s wireless keyboard but it packed in kept ghosting in key presses so sent it backI was originally looking at Keychron and NuPhy boards instead of the usual “gamer” brands, but… I ended up grabbing a Corsair K65 Plus Wireless recently, I am really happy with it so far.
It was (and still is) down to £99.99, I managed to get 20% off plus another 8% through my partner’s work voucher scheme, definitely a bargain considering its feature set.
The board is fully hot-swappable with north-facing LEDs, and it comes with PBT keycaps. They’re not shine-through, but that doesn’t bother me and they’re easy enough to swap if you want to.
You get both wired and wireless options (Bluetooth or 2.4GHz dongle), plus a Windows/Mac switch.
Corsair also added foam and a silicone layer inside, which improves the acoustics and overall feel. It gives the board a nice “thocky” sound.
It has more features than I need, feels and sounds very premium - It’s the perfect keyboard for me.
Yes in most basic terms, although the 100+ page thread on mechanical keyboards here would suggest there’s perhaps some nuance and depth to it too…What’s the difference between colour switches is it just the noise and the stiffness of the keypress?
I went with the k2 which has hall effect switches.Yer they look nice also. What model you got?
For gaming you’ll probably want linear switches that are light, such as Cherry MX Reds. Although different people have different preferences.
