I saw the random image thread says do not use "imgur, postimage or imgbb" I was only aware of imgur blocking the UK, not familiar with issues with the other two.
What alternatives to those three have you guys found most useful? (Figured a recommendation would be nice instead of the next result on google or whatever.)
Also does anyone know what the issue is with imgbb - like it doesn't store the images for long or something? I just used it now in a different thread but am wondering if I should edit the post and use a different host.
Edit - to make this thread useful:
The suggested solutions so far are:
Imgbox.com suggested by @tamzzy (also has a feature to automatically resize images) - note by @plasmahal it doesn't work on some other forums.
freeimage.host suggested by @Sonea Fifer and seconded by @darael
lensdump.com suggested by @Personality+
Also @Feek has helpfully clarified why the other two hosts aren't useful - it seems they're only hosting images for a short duration leading to a null image being displayed.
(note by @ubersonic that postimage does work well but some users are using it incorrectly - maybe fine for elsewhere in the forums then)
