PC hard locking when idle.stuck for solutions
23 Jan 2013
Hi
i have been having issue with my PC since i built it a few years ago and am now coming to the OCUK community for help as you are always good with these things and helpful.it has been doing this pretty much since i built it and i just can't seem to figure out what the issue could be.
I can use the PC for days/weeks without issue then the PC will lock up. This always happens when i walk away from the computer and leave it to idle. During gaming or watching youtube etc this never happens, well i think its happened once but 99% of the time its when i leave the computer to idle.
I instantly know it's hard locked up as my mouse will stop working, even if i unplug the mouse,theres no response so i have to hold down the power button and hard reset it.
No minidumps are present even though i have them setup.in the past i have tried to find out through event viewer and searching online but it always seemed vague and seemed to be multiple issues.have done multiple fresh windows installations. apart from taking parts out and and putting other parts (i don't have spare parts to do this) in to test through trial and error i really don't know what the issue could be hence me asking you lovely bunch of people if you can spot something i maybe missing?
Typically i have built my three kids a PC each and they run flawlessly but mine, yes mine has to be the headache machine as per usual lol.
sorry if image linking isn't allowed or anything.i have no idea how to upload an image of my event viewer on here.OCUK forum just tells me it cannot do it.
The system specs are:
1080P gaming machine
I-5 12400F
Team Group Vulcan Z T-Force 32B (4x8GB) DDR4 PC4-25600C16 3200MHz Dual
Asus Prime B660-PLUS D4 Motherboard
Gigabyte Radeon RX 560 Gaming OC 2048MB GDDR5 (soon to be swapped out for a Sapphire Radeon RX 5600 XT Pulse 6144MB 14GBPS GDDR6)
Crucial P5 Plus 1TB M.2 2280 PCI-e 4.0 x4 3D NAND NVMe Solid State Drive
Super Flower Golden Green HX 650W 80 Plus Gold
Arctic Freezer i35 Intel CPU Cooler
Aerocool Aero One Eclipse ARGB Mid-Tower
CPU idle temp 26c max 36c
GPU idle temp 56c
Have you tried with:
- XMP off
- C-States/EIST off OR highest power level in Windows power plan
What USB devices do you have?
How old is this?
There's absolutely nothing that could be significant? E.g. Plugging in an external device? Using a high draw device on another circuit? Using a program that you hardly ever use?
- XMP off
How old is this?
hi thanks for the reply.
XMP has always been off with the looks of it.i just found only 1 option in the bios relating to C-state just before you posted.i have disabled that but won't know for weeks or days if it worked.
USB wise the only things i have plugged in are mouse,keyboard and speakers.
programs are just steam games,firefox and brave.plugged in to the wall in my bedroom.no extensions etc
windows power plan is in high performance mode yes, with sleep etc disabled.also in advanced power options hard drive powering off is set to never instead of 20 minutes.
the power supply was bought from OCUK on 02.12.2022
These types of issues are sooo frustrating to track down. I'm assuming you are using all the latest drivers from the various websites.
If it's not a driver issue and you've done fresh Windows installs, then (as you
Have you tried running MemTest to give your RAM a workout?
When it locks up - have you tried to see if the Caps Lock key responds on the keyboard? (to rule out a dodgy mouse).
all drivers are up to date.i haven't tried the caps lock key,only unplugging the mouse and plugging it back in.i shall try the caps lock when it inevitably decides to crash at some point.also not done Memtest yet.how many passes do you recommend? i'll do it tomorrow when i get up.
