Any downsides to a smart meter?
Looking at moving from EDF to maybe Octopus but we currently have an old Economy 7 meter, is it worth changing this to a new smart one with EDF or after? I'm also going to look at getting rid of Economy 7 as we don't have storage heaters etc etc so no benefit to having cheaper electricity overnight.
I'd change to Octopus, then ask them for a smart meter. Otherwise you could run the risk of complicating and/or even delaying the switch between energy providers with relatively newly registered smart meters. I say this because it can take time for the new smart meters to connect to the network - depending on your area, hours, days or maybe weeks. In my area, my SMETS2 meters were sending readings back to EDF within in a couple of days.
Thank you, makes sense!
Will move to a variable tariff I think and then do some research into their smart tariffs :)
Do you have any batteries for home, if not id switch to octopus and go on their fixed tariff (no exit fee and going to be cheaper than the variable tariff) for a week or two to get some baseline data and then have a look at this
It will compare prices of various tariffs they offer, if you fancy a look they offer a "Try it out" mode where it uses dummy data to provide an example of what it does.
It will compare prices of various tariffs they offer.
No batteries, solar or anything like that :)
Cheers for the link, will have a look.
Do smart meter still have downsides?
I've a smart meter, all it does is save me having to do a meter reading. It doesn't really make me use less, we only ever use what we need. I could not use the tumble dryer but problem is the house would be damp and look like Mrs wishy washy laundry.
This is really useful, thank-you, I'd been wondering if Agile would make sense for me as I work shifts and tend to cook later in the evening so my energy usage is usually away from peak times, this makes it so much easier to see.
Sounds to me like it would suit you perfectly. My partner and I work 9-5 jobs and even we've still managed to save at least 20% on the standard unit price by load shifting the washing machine & dishwasher.
Still needs work lot of minor issues, getting overcharged, wrong reading, misuse by supplier, Not having control, Faults. they are a few things people had told me.
As someone working for a suppliers on the smart program, I would love to know of examples of all over the above.
Specifically what "control" are you looking for?
Control of not allowing energy company up-to-date or accurate meter readings.
All of those things can happen with a dumb meter and are nothing new to electricity billing.
Ironically, they are reduced with people who have smart meters.
You are probably right, to be honest I never cared, If it not broke.
No example mate, this is what I was told by others, I never cared much, so I never paid too much attention after, which is why Im asked on here.
I'm assuming control of what is happening with the meter, and not remote issues.
